Broadband cutting out
Mikrik7
Had broadband cutting out issues daily since xnas 2022
Latest communication stated that network work completed to fix issue
However still cutting out
1 ACCEPTED SOLUTION
Accepted Solutions
Legend
HUB Signal Level Checks
Via http://192.168.0.1/ connect to the Hub in Router mode, do not login in, scroll down to "Check router status"     Use http://192.168.100.1/ for a Hub in Modem mode
Using the Hub's "Check router status" tabs check the Downstream and Upstream power levels are in spec.
Downstream Power Levels of -7 to +7 dBmV are preferred, +10dBmV is the max acceptable, with a SNR of 33dB or higher across all DOCSIS 3.0 channels. Rising error counts across many channels is a current service noise fault.
Upstream
Power Levels of 35 to 49 dBmV are preferred, with QAM 64 Modulation mode across all four to six DOCSIS 3.0 channels.  Seeing QAM 32/16 is a current service noise fault.
16 REPLIES 16
Legend
Upstream
Akua_A
Hi @Mikrik7
Welcome to our community forums and thank you for your first posts.
Sorry to hear you have been having issues with broadband cutting out. We can understand the frustration caused. I can see you recently contacted our team who advised on this issue. Does the problem persist after the advise given? Do you need any further help?
Akua_A
Hi fault is still there
Nerwork work was apparently carried out
But hasn,t fixed b/band issues Called vm yet again to inform them
And what are the Hub stats like - are they within the ranges shown above?
Also, can we check… are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
Hi there @Mikrik7
Thank you so much for popping back to us and I am so sorry to hear that you have still been facing issues. I have checked and cannot see any outages present or any issues with the Hub specs on our side that may be causing issues.
Can I ask how things are looking since your last post?
Still issues re cutting out
Bad today
Wifi vg always connected to router on all devices but internet goes had loads of visits renewing of exterior and interior cables
Hi been on again to vm but got cut off
Lot of timeouts on router status ?
When i log in but doesn,t always coincide with cutting out of internet
Engineer 2wks ago said an issue was identified in network and work would be carried out  but still  losing internet but not disconnecting to router
And... what is the connection doing when the device is connected directly to the Hub on an ethernet cable ?
