  • 7
Broadband cutting out
Hi team, my children are doing school work from home. The internet keeps cutting out. Please can you advise further.
Also there is a beeping noise coming from my router.
please can someone help?
  • 11.97K
  • 933
  • 1.53K
Re: Broadband cutting out
What is your contracted speed ?
Which Hub do you have ?
Are you connecting to the Hub with Wi-Fi or ethernet cable ?
Mike Robinson
  • 11.97K
  • 933
  • 1.53K
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
