Robhorn
  • 6
Message 1 of 8
Broadband cutting out intermittently
Hello forum.  I have an issue with VM broadband service intermittently cutting out. The users who rely upon the broadband service initially reported to me that their Wifi signal was poor and instable, but all tests so far indicate that the Wifi coverage should be adequate. I've read through a number of past posts on this forum and the assistance looks to be excellent so I thought I'd give it a try. I have begun to collect stats and BQM as per previous posts. I will paste these next, but there are some significant things I would like expert opinion on, namely the T3 timeouts in the upstream channel stats and the repeating log message showing   "NOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;".    The message repeats and anything with "kernel" and "panic" in the same message must be of concern.   The BQM shows obvious and quite worrying outages but I haven't yet collected enough data to correlate logs/stats/BQM.
EDIT:   Virgin Media Hub 3
Any assistance would be very welcome.
BQM -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/47516b1a0f7dcc29b7098b583a47569aef...
Robhorn
  • 6
Message 2 of 8
Re: Broadband cutting out intermittently
Stats & logs
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
23600000
47.8
5120
64 qam
11
2
36600000
47.8
5120
64 qam
7
3
30100000
47.8
5120
64 qam
8
4
43100000
47.8
5120
64 qam
6
5
49599956
48
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
3
0
2
ATDMA
0
0
3
0
3
ATDMA
0
0
4
0
4
ATDMA
0
0
1
0
5
ATDMA
0
0
2
0
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
138750000
2.9
38
256 qam
1
2
146750000
2.7
38
256 qam
2
3
154750000
2.7
38
256 qam
3
4
162750000
2.7
38
256 qam
4
5
170750000
3
38
256 qam
5
6
178750000
3
38
256 qam
6
7
186750000
2.9
38
256 qam
7
8
194750000
2.7
38
256 qam
8
9
202750000
2.4
38
256 qam
9
10
210750000
2.2
38
256 qam
10
11
218750000
1.9
38
256 qam
11
12
226750000
1
38
256 qam
12
13
234750000
-0.2
37
256 qam
13
14
242750000
0.2
38
256 qam
14
15
250750000
1.2
38
256 qam
15
16
258750000
1.7
38
256 qam
16
17
266750000
1.9
38
256 qam
17
18
274750000
2
38
256 qam
18
19
282750000
2.2
38
256 qam
19
20
290750000
2.4
38
256 qam
20
21
298750000
2.7
38
256 qam
21
22
306750000
3
38
256 qam
22
23
314750000
3.7
38
256 qam
23
24
322750000
4.4
38
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
123
0
2
Locked
38.6
204
0
3
Locked
38.6
192
0
4
Locked
38.9
157
0
5
Locked
38.6
153
0
6
Locked
38.9
200
0
7
Locked
38.6
141
0
8
Locked
38.9
126
0
9
Locked
38.6
120
0
10
Locked
38.6
150
0
11
Locked
38.6
211
0
12
Locked
38.6
257
0
13
Locked
37.6
655
0
14
Locked
38.6
820
0
15
Locked
38.9
485
0
16
Locked
38.6
434
0
17
Locked
38.6
265
0
18
Locked
38.9
245
0
19
Locked
38.9
258
0
20
Locked
38.9
274
0
21
Locked
38.6
260
0
22
Locked
38.6
182
0
23
Locked
38.9
263
0
24
Locked
38.9
136
0
Time
Priority
Description
20/02/2023 14:47:24
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/02/2023 04:10:54
critical
19/02/2023 14:38:55
notice
19/02/2023 11:55:18
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
18/02/2023 03:10:16
critical
16/02/2023 20:11:39
notice
16/02/2023 19:08:15
critical
16/02/2023 16:16:47
notice
15/02/2023 23:55:18
Error
14/02/2023 01:03:39
notice
14/02/2023 01:03:10
notice
NOTICE ATOM is restarted due to RPC timeout as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/02/2023 18:37:22
notice
12/02/2023 11:55:18
Error
11/02/2023 15:00:34
critical
11/02/2023 14:46:51
notice
11/02/2023 04:59:6
critical
09/02/2023 01:23:20
notice
08/02/2023 23:55:18
Error
08/02/2023 14:53:21
notice
07/02/2023 11:24:22
critical
  • 35.11K
  • 3.41K
  • 6.68K
Message 3 of 8
BQM is not great, neither are ATOM in the logs...... but have you checked for any “known network faults first - Try in 2 places
1) Try the “check service,”Area status webpage" (link at top right of this forum)
2) Then also try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to street cab/ postcode level.
Robhorn
  • 6
Message 4 of 8
Thanks for your response, jbrennand.
I will check the service status, but this intermittent issue has been going on for several months with an engineer visit and a new router in the mix. Do you have any more insight on the data posted earlier, i.e. the red blocks in the BQM indicating 100% packet loss, I assume that this means the external monitor is attempting to poll my router but gets no response and therefore could be anything from a physical line issue to the router being switch off....is that correct? Also, can you explain what the ATOM messages mean? (What is ATOM, for starters?)
  • 35.11K
  • 3.41K
  • 6.68K
Message 5 of 8
Search this forum - there are loads od threads - strt here...
https://community.virginmedia.com/t5/Networking-and-WiFi/ATOM-Issues-on-Hub3/m-p/5205545
Red blocks mean the Hub is not responding to pings - so could be disconnections - but there is no evidence of any in the logs at those times suggests not - could just be a glitch in the Hub's firmware
Robhorn
  • 6
Message 6 of 8
Thanks for your response Jbrennand.  Looks like the ATOM messages represent a know issue with Hub 3.
Could really do with someone from VM responding on this issue.
Last few days of having the BQM running have shown what must be worrying behaviour from my Hub...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b26aaf6c62f52be44262c106cf6b95be71...
  • 35.11K
  • 3.41K
  • 6.68K
Message 7 of 8
What is being reported on the Network status number?
Molly_T
  • 1.9K
  • 63
  • 185
Message 8 of 8
Hi Robhorn 👋 welcome back to the community!
Thanks for posting. Sorry to hear you have been having some intermittent connection issues.
Having had a look at the BQM link you posted at the top of this thread there was no data showing on there (completely blocked out in red.) This indicates there may be an outage occurring in your area - it would be good to know if you were able to check the outage line 📞0800 561 0061 or 👉 https://virg.in/service.
However, I will need to send you a PM to confirm a few account details so we can investigate further and offer some support with this. You can find my PM in your Inbox in the top right corner of the page.  📩
We can return to this public thread with an update when possible. Thank you for your patience in the meantime!
Wishing you all the best. 🌞
Molly
