Hello HavenDK.
Thanks for popping over here.
I have just ran a quick check on your hub and we do have an issue with the signal strength that is coming into the property.
It's an easy fix by sending out a Technician.
So I can arrange this.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
