  • 12
Message 1 of 20
Broadband connection very poor quality
Dear Forum team,
My broadband connection appears to be very poor quality and I can barely maintain a voice signal without losing connection. I teach 200 students at a time over zoom, so this is highly embarrassing! Would it be possible to have a look at my connection? I cannot seem to speak to anyone at VM on the phone. I do appreciate it is a busy time. I have run the VM test, reset the hub, reset the wifi boosters (which normally work fine). It has been like this since September but was fine in the summer.
Any help/advice gratefully received as I am desperate!
  • 12.3K
  • 952
  • 1.58K
Message 2 of 20
Re: Broadband connection very poor quality
Firstly, VM do not and never have guaranteed Wi-Fi speed or coverage.
What is your connection like using a direct connection with a Cat 5E or better cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 12
Message 3 of 20
Thanks Mike, good question and I should have been clearer: quite often i measure it and it is >100Mbps but I have just been speaking to some students via Teams and it was 0.5Mbps latency 50ms and cutting out so much that they couldn't hear me. I know that everyone comes online in the mornings but my neighbours don't seem to have the same problem, so I wondered if it was something to do with me and my setup...
  • 12.3K
  • 952
  • 1.58K
Message 4 of 20
Use an ethernet connection if possible.
I have never used Teams so don't know the ins and outs of it.
In a previous life working for the MoD, we used to have a daily video meeting with Lockheed Martin in the USA and at the first sign of a problem we lowered the video fidelity but left the audio as normal, at the time we realised that what we said was more important than seeing someone blinking.
Can you do similar with Teams ?
Mike Robinson
  • 12.3K
  • 952
  • 1.58K
Message 5 of 20
Mike Robinson
  • 12.3K
  • 952
  • 1.58K
Message 6 of 20
Can you please
Mike Robinson
  • 12
Message 7 of 20
Thanks Mike, good ideas, I have already cut down the incoming video and my outgoing video and even then my voice is apparently cutting in and out. Seems odd when it sometimes speed testing at 70Mbps/10Mbps.
  • 12
Message 8 of 20
My BQM
  • 12
Message 9 of 20
Downstream
  • 12
Message 10 of 20
Upstream
