Broadband connection drops, issues with router
Having exhausted all possible solutions to this problem, (troubleshooting, resets, checking cables, endless conversations with robots over the phone), Im at my wits end as we’re a house of students trying to meet deadlines for an online course and it’s ridiculous.
After checking the router status directly, I’ve discovered a number of issues in the network log, I’ve found an error stating
No Ranging Response received - T3 time-our;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
After googling I found that this is possibly due to a low allocation of power to the Upstream of my router, Any assistance from forum staff would be greatly appreciated
  • 11.99K
  • 934
  • 1.53K
Re: Broadband connection drops, issues with router
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
  • 24.87K
  • 1.43K
  • 3.16K
Post the full network, upstream and downstream logs
I would have posted all of the information listed, my Internet hasn’t been stable enough to use on my pc to write this so I’ve had to use my mobile phone
