h5pdk
  • 28
Message 1 of 19
Broadband connection dropping
I have been having connection issues with my broadband now for sometime. This is also affecting both my 360 TV boxes so I'm am unable to watch recordings or catch up TV etc.
The broadband will work fine and then suddenly go off by its own accord, sometimes freezing and then sometimes losing connection altogether. When this happens if I disconnect my device I am using from the Internet it comes back on for a short time then the connection fails again.
I have tried rebooting the router but this does not seem to have helped with the issue. The connection is being lost on both wired PC's and wireless devices in the home. All the wiring is fine and the connections on all cables are secure and  tight.
I would appreciate it if a Virginmedia moderator could get in touch with me as things have got that bad I'm having to use my phones 4g connection.
Robert_P
  • 2.47K
  • 123
  • 202
Message 2 of 19
Re: Broadband connection dropping
Hello h5pdk
Sorry to hear of the broadband connection issues and the inconvenience this is causing you, we appreciate you taking the time to contact us via the forums to make us aware.
I've arranged for a technician to attend tomorrow between 8am and 12pm, please let me know if there are any individuals shielding or if the appointment isn't convenient for you.
Rob
h5pdk
  • 28
Message 3 of 19
Morning Rob, I had the tech guy out yesterday. He changed my hub plus another box and some wiring but unfortunately the fault is still there. Please advise on what to do next
lotharmat
  • 770
  • 53
  • 108
Well-informed
Message 4 of 19
Can you post your Hub status and logs?
Someone should be spot if there is a problem
Navigate to http://192.168.0.1 (or http://192.168.100.1 - if in modem mode)
Don't log in!
Click on 'router status'
Copy/paste the data from each of the tabs. The forum software will remove the MAC addresses for you (you may need to click the 'post' button again).
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc - You can do this at ThinkBroadband (https://www.thinkbroadband.com/broadband/monitoring/quality)
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum!
Kath_F
  • 27.39K
  • 1.05K
  • 2.04K
Message 5 of 19
Hi h5pdk,
Thanks for coming back and letting us know how things went with the engineer. I'm sorry that the issue is continuing for you.
Based on the fact the Hub was changed, we can rule a faulty hub being the cause atleast.
I have checked the connection, and all is looking well at the moment.
I think it would be best to set up a BQM graph as mentioned above by lotharmat so we can view the continuous stats.
Could you also connect the Hub to a pc or laptop via an ethernet cable, reboot the Hub and then run a speed test through speedtest.net and post the results here so we can look at them.
Many thanks,
Kath_F
h5pdk
  • 28
Message 6 of 19
Cable Modem Status
Item Status Comments
402750000
Locked
Ranged Upstream Channel (Hz)
60300000
Locked
Provisioning State
Online
 data
1 402750000 0.4 40 256 qam 30
2 202750000 -0.4 40 256 qam 9
3 210750000 -0.7 40 256 qam 10
4 218750000 -0.9 40 256 qam 11
5 226750000 -1 40 256 qam 12
6 234750000 -1 40 256 qam 13
7 242750000 -0.9 40 256 qam 14
8 250750000 -0.7 40 256 qam 15
9 258750000 -0.4 40 256 qam 16
10 266750000 -0.4 40 256 qam 17
11 274750000 -0.4 40 256 qam 18
12 282750000 -0.2 40 256 qam 19
13 290750000 0 40 256 qam 20
14 298750000 0.2 40 256 qam 21
15 306750000 0.2 40 256 qam 22
16 314750000 0.4 40 256 qam 23
17 322750000 0.7 40 256 qam 24
18 330750000 1 40 256 qam 25
19 370750000 0.4 40 256 qam 26
20 378750000 0.2 40 256 qam 27
21 386750000 0 40 256 qam 28
22 394750000 0.5 40 256 qam 29
23 410750000 0.2 40 256 qam 31
24 418750000 0 40 256 qam 32
1 Locked 40.3 7 0
2 Locked 40.3 15 0
3 Locked 40.3 10 0
4 Locked 40.3 43 6
5 Locked 40.9 39 2
6 Locked 40.3 30 0
7 Locked 40.9 41 1
8 Locked 40.3 9 0
9 Locked 40.3 12 0
10 Locked 40.3 11 0
11 Locked 40.3 16 0
12 Locked 40.3 16 0
13 Locked 40.9 8 0
14 Locked 40.3 24 0
15 Locked 40.9 11 0
16 Locked 40.3 7 0
17 Locked 40.9 26 0
18 Locked 40.9 5 0
19 Locked 40.9 3 0
20 Locked 40.3 7 0
21 Locked 40.9 6 0
22 Locked 40.9 6 0
23 Locked 40.9 11 0
24 Locked 40.3 5 0
1 60300000 48.8 5120 32 qam 1
2 39400007 48.8 5120 32 qam 4
3 46199986 48.8 5120 32 qam 3
4 53700014 48.8 5120 32 qam 2
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 1 0
SFID 1372
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 1367
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
Refresh data
28/04/2021 16:05:10 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/04/2021 09:59:53 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 16:09:26 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 16:09:26 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 15:35:8 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 15:09:26 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 15:09:26 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 14:39:26 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 14:39:26 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 14:09:26 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 14:09:26 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 13:39:26 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 13:39:26 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 13:09:26 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 13:09:26 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 12:39:26 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 12:39:26 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 12:09:26 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 12:09:26 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/04/2021 11:39:25 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0
Sasha_W
  • 896
  • 37
  • 65
Message 7 of 19
Thanks for coming back to us @h5pdk
I would advise just monitoring it over a couple of days, and if the speeds are still low then I would advise coming back on here and we can look through it.
Everything does look okay for me on the account, there are no faults or outages that could be causing issues but please do keep us updated.
Sasha - Forum Team
h5pdk
  • 28
Message 8 of 19
It isn't a speed problem it is the fact that the connection fails altogether. I am monitoring the connection on think broadband and will post the results in a couple of day.
Sasha_W
  • 896
  • 37
  • 65
Message 9 of 19
Oh I see, thanks for this,
If you could just post it in a couple of days that would be fab and we will certainly look into this if you're still experiencing a lot of drop outs.
Sasha - Forum Team
lotharmat
  • 770
  • 53
  • 108
Well-informed
Message 10 of 19
Upstream should be 64 QAM - Not 32 shouldn't it‽
