  • 11
Message 1 of 13
Broadband connection dropping regularly
Over the last few weeks our broadband has been disconnecting almost daily.
About 60% of the time rebooting the Virgin router seems to fix the issue, not sure if it's just co-incidence.
A factory reset of the router hasn't resolved the issue.
Our local Virgin Media broadband service status says everything is ok when we check.
This affects both wired and wireless devices and is making wfh difficult.
Router info:
Software Version: V1.01.35
Hardware Version: 3.11
What can be done to fix this issue?
  • 12.06K
  • 939
  • 1.54K
Message 2 of 13
Re: Broadband connection dropping regularly
Mike Robinson
  • 24.94K
  • 1.44K
  • 3.17K
Message 3 of 13
Port the network, upstream and downstream logs from the hubs admin pages, as text please
  • 12.06K
  • 939
  • 1.54K
Message 4 of 13
Can you please
Mike Robinson
  • 11
Message 5 of 13
Downstream DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 563000000 539000000 547000000 555000000 571000000 579000000 587000000 595000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 20 17 18 19 21 22 23 24
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17 I=12
J=17
Power Level (dBmV) -3.54 -3.52 -3.55 -3.72 -3.89 -3.69 -3.64 -3.42
RxMER (dB) 37.94 37.64 37.64 37.09 37.94 37.94 37.94 37.94
Pre RS Errors
1357 2217 1148 1202 1116 1133 1211 1254
Post RS Errors
1011 965 938 956 904 937 1008 1011
  • 11
Message 6 of 13
Upstream US-1 US-2 US-3 US-4
Channel Type 2.0 2.0 2.0 2.0
Channel ID 4 2 3 5
Frequency (Hz) 39400000 53700000 46200000 32600000
Ranging Status Success Success Success Success
Modulation 64QAM 64QAM 64QAM 64QAM
Symbol Rate (Sym/sec) 5120000 5120000 5120000 5120000
Mini-Slot Size 2 2 2 2
Power Level (dBmV) 49.75 49.75 49.75 49.75
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 0 0 0 0
T4 Timeouts 0 0 0 0
  • 11
Message 7 of 13
General Configuration Network Access Allowed
Maximum Number of CPEs 1
Baseline Privacy Enabled
DOCSIS Mode EuroDOCSIS 3.0
Config File
Primary Downstream Service Flow SFID 11499
Max Traffic Rate 117000047 bps
Max Traffic Burst 42600 bytes
Min Traffic Rate 0 bps
Primary Upstream Service Flow SFID 11498
Max Traffic Rate 10500047 bps
Max Traffic Burst 16320 bytes
Max Concatenated Burst 16320 bytes
Scheduling Type Best Effort
  • 11
Message 8 of 13
Network Log First Time Last Time Priority Error Number Description
16/11/2020 12:11:22 GMT 16/11/2020 12:11:22 GMT Warning (5) 66050300 Auth Fail - Web login failed.
16/11/2020 12:11:12 GMT 16/11/2020 12:11:12 GMT Warning (5) 66050300 Auth Fail - Web login failed.
16/11/2020 12:11:07 GMT 16/11/2020 12:11:07 GMT Warning (5) 66050300 Auth Fail - Web login failed.
16/11/2020 11:55:36 GMT 16/11/2020 11:55:36 GMT Warning (5) 66050310 Auth Success - Web login successful.
16/11/2020 11:54:27 GMT 16/11/2020 11:54:27 GMT Warning (5) 66050310 Auth Success - Web login successful.
16/11/2020 11:52:14 GMT 16/11/2020 11:52:14 GMT Warning (5) 66050300 Auth Fail - Web login failed.
16/11/2020 11:51:50 GMT 16/11/2020 11:51:50 GMT Warning (5) 66050300 Auth Fail - Web login failed.
16/11/2020 10:46:25 GMT 16/11/2020 10:46:25 GMT Error (4) 68010302 DHCP WAN IP - 86.19.119.27
16/11/2020 10:45:17 GMT 16/11/2020 10:45:17 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
16/11/2020 08:53:59 GMT 16/11/2020 08:53:59 GMT Error (4) 68010302 DHCP WAN IP - 86.19.119.27
16/11/2020 08:52:56 GMT 16/11/2020 08:52:56 GMT Error (4) 68000407 TOD established
13/11/2020 19:19:37 GMT 13/11/2020 19:19:37 GMT Error (4) 68010302 DHCP WAN IP - 86.19.119.27
13/11/2020 19:18:34 GMT 13/11/2020 19:18:34 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Critical (3) 82000200 No Ranging Response received - T3 time-out
12/11/2020 13:14:41 GMT 12/11/2020 13:14:41 GMT Notice (6) 68010600 DHCP Renew - lease parameters tftp file-******** modified
12/11/2020 13:14:41 GMT 12/11/2020 13:14:41 GMT Error (4) 68010300 DHCP RENEW WARNING - Field invalid in response v4 option
09/11/2020 18:45:02 GMT 09/11/2020 18:45:02 GMT Warning (5) 66050310 Auth Success - Web login successful.
  • 11
Message 9 of 13
Thank you both for the help, I have signed up for the broadband monitoring service, link below:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/3171edbcac1aa5c443c739fd572a13b712...
  • 11
Message 10 of 13
Just out of interest does this 'thinkbroadband' monitoring basically just ping your external IP and log the results?
