Broadband & WiFi Dropping issues Hub 3
ChrisNight
Over the last month or so my broadband connection has been really unreliable.
The broadband connection drops (happening at least once a day) then after rebooting the Hub3 takes about 20 mins to reconnect (which it doesn't always do).   I've checked the Service Status etc and there are no local problems although when running an automated check it says there are problems in my area.
The other odd thing thats happening is that the Wireless seems to drop by itself and takes lots of reboots before Phones etc. are able to connect (after rebooting them).
This is becomming a bit of a nightmare as both myself and my wife work from home and the connection is vital,especially for my wife.
I've checked the router logs and done broadband speedtests etc. and there's nothing standing out other than the errors below in the router logs and the light on the Hub3 is orange (which doesn't seem to mean much from what I can see after searching around).
I've reset everything I can. Checked all the cables and sworn a few times 🙂  etc.
Has anyone got any suggestions, as I don't want to spend hours on 150 and can't find any sort of Virgin Live chat ?
1 ACCEPTED SOLUTION
Accepted Solutions
We need the full stats;
How to get stats from a VM hub (no need to logon to the hub)
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
  • Click on the “> Check router status” button
  • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
  • Click on the “Upstream” tab, copy the text and paste into your reply
  • Click on the “Networking” tab, copy the text and paste into your reply.
    • Do NOT post photos or screen shots they will be rejected as they contain MAC addresses. The board software will automatically change MAC addresses to **:** if done as above.
10 REPLIES 10
12347500002.440256 qam13
21387500004.940256 qam1
31467500004.640256 qam2
41547500004.540256 qam3
5162750000440256 qam4
61707500003.940256 qam5
71787500003.540256 qam6
81867500003.240256 qam7
91947500003.240256 qam8
10202750000340256 qam9
112107500002.740256 qam10
122187500002.540256 qam11
132267500002.540256 qam12
14242750000240256 qam14
152507500002.240256 qam15
16258750000240256 qam16
172667500001.740256 qam17
182747500001.440256 qam18
192827500001.440256 qam19
202907500001.440256 qam20
212987500001.440256 qam21
223067500000.740256 qam22
233147500000.940256 qam23
243227500001.240256 qam24
1Locked40.970
2Locked40.3200
3Locked40.9190
4Locked40.9210
5Locked40.3220
6Locked40.9240
7Locked40.9190
8Locked40.360
9Locked40.960
10Locked40.940
11Locked40.980
12Locked40.980
13Locked40.340
14Locked40.310
15Locked40.350
16Locked40.960
17Locked40.950
18Locked40.950
19Locked40.960
20Locked40.970
21Locked40.310
22Locked40.980
23Locked40.980
24Locked40.990
14960003142.5512064 qam1
22360000040.5512064 qam5
33010000241512064 qam4
43660000042.5512064 qam3
54310000442.5512064 qam2
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
3ATDMA0000
4ATDMA0000
5ATDMA0000
26/05/2023 01:57:0criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/05/2023 18:10:0noticeNOTICE ATOM is restarted due to Kernel/oops panic as part of Self Healing Mechanism ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/05/2023 04:07:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/05/2023 01:07:32noticeSW download Successful - Via NMS
25/05/2023 01:05:18noticeSW Download INIT - Via NMS
23/05/2023 04:55:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:47:48criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:47:25Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:46:49Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:45:20Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:45:20Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:44:42Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:44:42Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:43:35Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:43:35Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:42:57Warning!MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/05/2023 04:42:57Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Hi @ChrisNight
Welcome to our community forums and thank you for your first posts.
Sorry to hear you have been having intermittent services with us. We can understand the inconvenience caused when trying to work from home. I have been able to run some tests on your service and I can see there is currently an SNR outage affecting your service. Our teams are doing their best to resolve the issue and to get the service up and running again. The estimated fix time for this is currently 29 MAY 2023 13:20. If the issue persists after this, please let us know and we can run further tests for a resolution.
Akua_A
ChrisNight
Hi @Akua_A ,
Thank you for your reponse.  It doesn't look like it's been fixed.
The connection has gone down again this morning @ 10:15.  This is getting beyond a joke.
Rebooted the router to get it back and running although nothing can connect to wireless now.
Can you please let me know when you think this will be fixed properly as it's been going on for a long while now and this really isn't an acceptable situation.
Intenet is up currently.
Hello ChrisNight.
Thankyou for your reply.
Sorry to hear about the service and connection not behaving as it should.
I did take a look and can see we have an SNR issue on your local Network.
This is due to be fixed on if not before the 05/06/2023 at 18:00.
Can you please pop back on here and quote reference number F010681241 if you are still having the same issue.
We will be able to keep you updated.
Apologies for any inconvenience this may be causing you.
Gareth_L
F010681241
This keeps happening at roughly the same time each day and you keep pushing the fix date out.
It's not really good enough. I pay a lot of money for the broadband I have and I expect more reliabilty
than I currently receive.
I've been a customer for 24 yrs and never had any major issues until the 6 -8 months.
Are you going to provide any recompence for the poor service t'm currently getting ?
Joseph_B
Hey @ChrisNight,
Thanks for getting back to us, sorry that you are still experieicning this issue.
Rest assured we will be looking into this for you, unfortunately some faults can take us longer to resolve and in these cases we will push back the estimated fix time.
You can find out about how we compensate our customers and if you are eligible via our website here.
Cheers. Joe
The problem is still happening at least once a day, normally circa 10am - 10:30am most days.
A modem reboot usually resolves the problem, but that's not really good enough.
I can't claim any compensenation from yourselves as it's not down for a day.
My wife's job is reliant on a consistant service and online phone connection as she
works with safeguarding and needs to be able to take calls and not have them drop
in the middle of a call.
Please don't reply with it's a known fault and it will be fixed next Monday as you've been saying that for over a month now!!!!!!!!!!
