on 21-07-2023 17:24
I'm getting connection loss 2-3 times an evening on average causing issues playing online games. The issue has been going on for about 6 weeks.
I run a continuous ping to bbc.co.uk most evenings and can see around 3-6 seconds of no connection out during the time of the issue.
Answered! Go to Answer
on 17-08-2023 13:14
Engineer attended a week ago and I've had no problems since.
Thanks.
on 21-07-2023 18:10
See this...
Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 21-07-2023 19:26
Thanks for your advice.
1 | 139000000 | 4.4 | 40 | 256 qam | 1 |
2 | 147000000 | 4.5 | 40 | 256 qam | 2 |
3 | 155000000 | 4.5 | 40 | 256 qam | 3 |
4 | 163000000 | 4.1 | 40 | 256 qam | 4 |
5 | 171000000 | 4.3 | 40 | 256 qam | 5 |
6 | 179000000 | 4.3 | 40 | 256 qam | 6 |
7 | 187000000 | 4 | 40 | 256 qam | 7 |
8 | 195000000 | 3.9 | 40 | 256 qam | 8 |
9 | 203000000 | 3.7 | 40 | 256 qam | 9 |
10 | 211000000 | 3.4 | 40 | 256 qam | 10 |
11 | 219000000 | 3 | 40 | 256 qam | 11 |
12 | 227000000 | 2.4 | 40 | 256 qam | 12 |
13 | 235000000 | 2.2 | 40 | 256 qam | 13 |
14 | 243000000 | 2.4 | 40 | 256 qam | 14 |
15 | 251000000 | 2.5 | 40 | 256 qam | 15 |
16 | 259000000 | 2.7 | 40 | 256 qam | 16 |
17 | 267000000 | 3 | 40 | 256 qam | 17 |
18 | 275000000 | 3.2 | 40 | 256 qam | 18 |
19 | 283000000 | 3.4 | 40 | 256 qam | 19 |
20 | 291000000 | 3.4 | 40 | 256 qam | 20 |
21 | 299000000 | 3.5 | 40 | 256 qam | 21 |
22 | 307000000 | 3.5 | 40 | 256 qam | 22 |
23 | 315000000 | 3.7 | 40 | 256 qam | 23 |
24 | 323000000 | 3.9 | 40 | 256 qam | 24 |
1 | Locked | 40.3 | 8075 | 3718 |
2 | Locked | 40.3 | 7058 | 2978 |
3 | Locked | 40.3 | 6980 | 2623 |
4 | Locked | 40.3 | 6304 | 2480 |
5 | Locked | 40.3 | 6330 | 2118 |
6 | Locked | 40.3 | 5033 | 1846 |
7 | Locked | 40.3 | 4314 | 2021 |
8 | Locked | 40.9 | 4295 | 2070 |
9 | Locked | 40.9 | 4711 | 1910 |
10 | Locked | 40.9 | 4780 | 2038 |
11 | Locked | 40.3 | 4760 | 1940 |
12 | Locked | 40.3 | 4677 | 1819 |
13 | Locked | 40.3 | 4365 | 1958 |
14 | Locked | 40.9 | 3806 | 2007 |
15 | Locked | 40.9 | 3561 | 1748 |
16 | Locked | 40.3 | 3093 | 1771 |
17 | Locked | 40.3 | 2732 | 1791 |
18 | Locked | 40.3 | 2312 | 1553 |
19 | Locked | 40.9 | 2125 | 1532 |
20 | Locked | 40.9 | 1900 | 1685 |
21 | Locked | 40.3 | 1778 | 1469 |
22 | Locked | 40.3 | 1427 | 1562 |
23 | Locked | 40.3 | 1229 | 1473 |
24 | Locked | 40.3 | 1149 | 1612 |
1 | 43100000 | 48.3 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 9 | 0 |
21/07/2023 11:59:4 | critical | No Ranging Response received - T3 time-out;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 11:27:26 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 08:50:1 | Warning! | RCS Partial Service;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 08:49:48 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 07:35:29 | critical | No Ranging Response received - T3 time-out;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 01:34:11 | Warning! | RCS Partial Service;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 01:34:11 | critical | No Ranging Response received - T3 time-out;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 01:34:4 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 01:16:53 | critical | No Ranging Response received - T3 time-out;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 00:32:21 | Warning! | RCS Partial Service;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 00:32:21 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 00:30:51 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 00:26:26 | Warning! | RCS Partial Service;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
21/07/2023 00:20:58 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
20/07/2023 23:33:23 | Warning! | RCS Partial Service;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
20/07/2023 23:28:29 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
20/07/2023 22:36:7 | Warning! | RCS Partial Service;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
20/07/2023 21:20:55 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
20/07/2023 21:20:50 | Warning! | RCS Partial Service;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
on 22-07-2023 15:41
If you really only have one upstream channel (should be 4) then thats a real issue.
Try again after switching Hub off for 5 minutes and restarting. If still only one channel, report back here and call it in as a faut
on 23-07-2023 15:12
Power off for 5+ mins resulted in 5 channels;
1 | 43100000 | 47.8 | 5120 | 64 qam | 2 |
2 | 49600000 | 48.3 | 5120 | 64 qam | 1 |
3 | 23600000 | 47 | 5120 | 64 qam | 5 |
4 | 30100000 | 47.3 | 5120 | 64 qam | 4 |
5 | 36600000 | 47.5 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
I'll see how that performs for a day or two.
Am playing an online game regularly so notice drop outs as disconnections so should tell within that time if things have improved.
Thanks for the advice.
25-07-2023 13:36 - edited 25-07-2023 14:09
I had another period of disconnection early this morning, not long after midnight.
Checking the modem I can see I have dropped to single upstream again;
1 | 43100000 | 54.3 | 5120 | 64 qam | 2 |
1 | ATDMA | 0 | 0 | 7 | 0 |
During the time between the modem power down for more than 5 mins and then I had zero problems (although occasionally had someone tell me in chat that my voice went robotic at times but that could easily be the Playstation Network).
Edited: Updated image
on 25-07-2023 18:10
Just had a 2-3 minute outtage during which I could not reach the modem via internal IP at all. Was mid-game at the time, and then I wasn't....
25/07/2023 17:04:0 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
25/07/2023 17:03:58 | Warning! | RCS Partial Service;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
25/07/2023 17:03:45 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
25/07/2023 16:38:0 | critical | No Ranging Response received - T3 time-out;CM-MAC=XXXX;CMTS-MAC=YYYY;CM-QOS=1.1;CM-VER=3.0; |
on 26-07-2023 11:37
Hi Tenaka30 👋🏼.
Thank you for posting. Welcoming you back onto the community forum 😊.
Sorry to see you are having issues with your dropping connection ☹.
So I can get a better understating of this, does the connection drop out only when you are playing games?
How is your connection now?
You can also click this link to see if there are any potential issues in the area that maybe causing the drop out of connection.
Please let us know how you get on.
Thank you.
Ari - Forum Team
26-07-2023 12:25 - edited 26-07-2023 12:27
The connection is reverting to a single upstream channel with an excessive power level. This indicates a fault either in the Hub or in the local cabinet. This needs a technician visit to find and correct the fault.
This has nothing to do with how the OP is using it.
on 26-07-2023 16:37
Hi Arissa,
I would only notice when I am playing games but using the think broadband tool I can see the issue occurs randomly throughout the day and night.
There was an issue around 05:00 this morning for example when I was asleep. I was at work by 8 when there were other issues.
I started out by checking for issues in my area but each time I have checked there were not.
Thanks for the input jpeg1.
