  • 5
Message 1 of 5
Broadband Connection Dropping Out
I have noticed my connection has been dropping out several times a day recently. Any ideas based on my router status?
363000000
Locked
Ranged Upstream Channel (Hz)
32599939
Locked
Provisioning State
Online
  • 5
Message 2 of 5
Re: Broadband Connection Dropping Out
13630000005.538256 qam29
22030000003.238256 qam9
32110000003.437256 qam10
42190000003.538256 qam11
52270000003.538256 qam12
62350000003.738256 qam13
72430000003.538256 qam14
82510000003.538256 qam15
92590000003.938256 qam16
10267000000438256 qam17
112750000003.738256 qam18
122830000004.338256 qam19
132910000005.338256 qam20
142990000005.338256 qam21
153070000005.138256 qam22
16315000000538256 qam23
173230000005.138256 qam24
183310000005.338256 qam25
19339000000538256 qam26
203470000005.338256 qam27
213550000005.438256 qam28
223710000005.538256 qam30
233790000005.538256 qam31
243870000005.338256 qam32
1Locked38.660
2Locked38.670
3Locked37.690
4Locked38.6110
5Locked38.660
6Locked38.690
7Locked38.980
8Locked38.660
9Locked38.990
10Locked38.960
11Locked38.670
12Locked38.660
13Locked38.910
14Locked38.690
15Locked38.690
16Locked38.9100
17Locked38.680
18Locked38.670
19Locked38.690
20Locked38.6120
21Locked38.620
22Locked38.9120
23Locked38.6100
24Locked38.650
13259993941.3512064 qam3
22579992041.3512064 qam4
33940000041.3512064 qam2
44620000941.3512064 qam1
2ATDMA0010
3ATDMA0000
4ATDMA0000
  • 5
Message 3 of 5
16/11/2020 07:56:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 22:32:38noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 22:32:38ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 20:23:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 04:09:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 04:09:47criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 04:08:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 04:08:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 04:07:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 04:07:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 04:00:27Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 04:00:26criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 03:59:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 03:59:45criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 03:58:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 03:58:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 03:57:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 03:57:57criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 03:28:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 03:28:26criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 783
  • 39
  • 62
Message 4 of 5
Hi there @sky0000547
Welcome to the community and thank you for your post. Apologies for the delay in response, we have been very busy and doing all we can to get to each customer ASAP. Thanks for your patience.
Sorry to hear you've been having these broadband connection drops. Have you been using a wired or wireless connection? How has the connection been since?
Let us know and we'll do our best to help.
Hollie - Forum Team
  • 5
Message 5 of 5
Hi @Hollie_B
Thanks for the reply.
The dropout was for both wired and wireless connections. It does appear to be better today.    Has something been done to it?
