eh95
Broadband Coax Cable
Hi, my dad was fitting new skirtings today and accidentally pulled the coax cable out the wall, he then put it back on but I wasn't getting an internet connection. On inspection he saw that part of the wiring inside was bent. After several reboots the WiFi has finally came back on but I was wondering where is best to get another coax cable as this one is damaged?
I tried the live chat and phoning the number it gave me but from there it just did a service check on the box that said the cable wasn't plugged in
Thanks in advance for any help
Tags (2)
apcyberax
  • 33.38K
  • 1.87K
  • 5.93K
Re: Broadband Coax Cable
call it in or wait here for VM staff to get to the post in a week and they can arrange an engineer
g0akc
  • 566
  • 59
  • 118
Rising star
Is the internet working?
if you need a new cable you will need to ring Virgin and likely have a technician visit - only they can supply the cables - you’re not supposed to use any from elsewhere.
They will likely charge for a visit (£99?) as your fault - not their fault.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
sayekm
  • 304
  • 26
  • 56
Fibre optic
Step 1. Measure the length of the original cable
Step 2.  Find a Virgin van on the street.
Step 3. Speak to the Virgin engineer very politely and ask for a same length cable. May need to negotiate how many drinks the engineer would accept.
Step 4. Replace cable at home.
Warning.. replace cable at own risk. If you not got a clue don't try this at home.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
M200 Oomph - 5GB SIM + 3 extra SIM family plan - BT whole Wi-Fi - Sky Q
Don't cry over Virgin price increase instead speak to retentions team and negotiate a better deal.
