What speed do you get on https://speedtest.samknows.com/ with direct wired connection from PC/Laptop to router using a Cat 5e cable or better with a 1Gbps capable Ethernet network card?
- Make sure the cable is Cat 5e or better
- Make sure your PC/laptop has a 1Gbps or better network card
- Make sure Hub is NOT in modem mode
- Disconnect all other Ethernet cables when running the test
Also when you say "50Mb/s " is that downloading a file or is this a speedtest at 50mbps?
