@VCRBee wrote:
I’ve seen several queries here about not being able to order boosters for the hub 4 since it’s not compatible with the app.
I have the same problem. And nowhere on the website can I find an option to order them directly. The chatbot doesn’t even understand the question!
Can someone at VM please get these ordered for me? Think I’ll need x2
Thank you.
The boosters have been retired. You can call in and request a new Wifi Pod, which you'll get for free if you're on the 1gb package, or ultimate oomph, otherwise they cost £5 per month.
They are apparently out of stock at the moment though..
if you are eligible for a free one you may as well give it a go.. if you have to pay then it's probably better to put the money towards purchasing your own wifi kit.
