Message 1 of 7
Booster kit - Router does not have anough ethernet ports for booster ethernet
HI - I have ordered a booster kits due to blackspots around the house.  It has arrived but needs to connect to router via ethernet - I have no available ports in router as i work from home and am connected direct to router via work equipment
How can i connect booster to router?
  • 17.52K
  • 1.84K
  • 3.05K
Message 2 of 7
Re: Booster kit - Router does not have anough ethernet ports for booster ethernet
Get an unmanaged 1GB port network switch with the number of ports you need - 5-8 port ones are <£20 from the usual online places.  Plug it into the Hub with a short (Cat6) ethernet cable and then connect extra devices to it.
  • 14.78K
  • 622
  • 1.42K
Message 3 of 7
You could try a switch and get your own wireless router with 1Gb ports use the hub in modem mode.
Message 4 of 7
Thank - I am not at all technical and have no man at home to assist - Is a netgear gs308 with 8 ports ok?
  • 17.52K
  • 1.84K
  • 3.05K
Message 5 of 7
Yes an excellent choice - no man could have chosen more wisely 🙂
Remember you will also need an ethernet cable of the right length to connect it to the Hub from where you put the switch and have it plugged in. Get a Cat6 one as they have better "shielding"
Message 6 of 7
Thanks - What length
  • 12.14K
  • 943
  • 1.55K
Message 7 of 7
Long enough to reach the Switch at the place that you want to position it, not forgetting the Switch also needs mains power.
Mike Robinson
