Message 1 of 7
Booster connected but not broadcasting
Hello,
My powerboost was system was working just fine for the last few months.  It broadcasts a VMP network name, so I know when its broadcasting.  This morning it stopped broadcasting.  I have restarted everything, including the hub.  The booster is connected to the internet, as the computer plugged into the booster with an ethernet cable works fine.  But not wifi broadcast.
I tried pushing the wifi button on the side several times to see if it made a difference.  No change.
Any ideas?
  • 20.96K
  • 1.14K
  • 2.7K
Message 2 of 7
Re: Booster connected but not broadcasting
Reset it.
Or get some better equipment
  • 2.6K
  • 153
  • 330
Message 3 of 7
Hi stuartlwilliams, thanks for your post.
If it's VM boosters you're having problems with the troubleshooting guide here may offer a solution: https://www.virginmedia.com/help/virgin-media-booster-troubleshooting
Hope this helps.
Tom
Message 4 of 7
They are VM boosters. I have done all the troubleshooting. Followed all the guides, reset, etc. No luck.
It connected to the internet fine. White light is only light on. But no wifi broadcast.
In fact, just plugged in an old draytek to the booster via ethernet and set that to share wifi, and that's working. So why won't the VM booster broadcast a wifi?
  • 20.96K
  • 1.14K
  • 2.7K
Message 5 of 7
Are they broadcasting the same SSID as the hub?
What makes you believe they’re not broadcasting?
Message 6 of 7
VMP is the default start name to the booster wifi.  Half my house was connected to it.  Now that Wifi network doesn't exist.
The main router is VM..... and is working.
  • 3.01K
  • 167
  • 278
Message 7 of 7
Hi stuartlwilliams,
I'm sorry if you've already tried this but have you tried resetting the WiFi Boosters back to factory and set it up again to see if it it pops up? Can you confirm that the lights on the boosters are on? Can none of your devices see the network?
Sorry for all these questions, just trying to get a clearer picture.
Lisa
