Blue light on Hub
steve1711
My replacement hub (previous one had a permanent red light) has a constant blue light on the front of it. I can connect to the hub but it has no internet connection.
I have tried hard and soft resets. The boys at HQ say there is nothing wrong with my service. Any ideas?
4 REPLIES 4
Legend
Which VM Hub do you have ?
Joseph_B
Hey @steve1711,
Welcome back to the Community Forums and thanks for the post.
Sorry to see you were having this issue with your Hub, has this since been rectified since your post?
Joe
Engineer came today, Virgin call centre I phoned initially hadn’t pinged the hub properly so it hadn’t activated. I am disappointed because I asked them specfically and they said they had.
That said the engineer was a top man and had it sorted very quickly.
Kain_W
Sincere apologies for the issues faced steve1711,
I'm glad however the technician was able to get this sorted.
If you do have any future queries then be sure to pop back up to the team for further assistance.
Regards,
Kain
