Message 1 of 5
Best wifi router for hub 3
Looking at turning hub into modem and buying separate wifi router. Any recommendations much appreciated
thanks
  • 24.56K
  • 1.41K
  • 3.12K
Message 3 of 5
Re: Best wifi router for hub 3
Plenty. ASUS are well renowned.
  • 19.64K
  • 1.72K
  • 4.29K
Message 4 of 5
well helpful to do know, what devices, do you plan to use with it?, are you more interested over speed to distance?, does it need to have usb ports?, like to have advanced filter to block certain sites/apps etc.
  • 17.34K
  • 1.82K
  • 3.02K
Message 5 of 5
Look at Mesh systems too. The first unit is the new modem, other modules then distribute the wifi around your property.
