Put the Hub into modem mode …
To enable modem mode on your Hub
- Make sure you are connected (wired or wirelessly) to your Hub
- Open your Internet browser
- Log in to your Hub's settings page by entering 192.168.0.1 into the address bar of your Internet browser
- Enter your Hub settings password. The default password is on the bottom of the Hub. If you have changed the default password, enter that password instead
- Once you've logged in, click Modem Mode on the left
- Click the option next to Enable Modem Mode and then click Apply changes and wait for the base light to turn magenta.
Note: Once in Modem Mode, the IP address you use to access your Hub changes from 192.168.0.1 to 192.168.100.1.
then
- Disconnect all ethernet cables from the Hub then power off the Hub.
- Set up your own router with the WAN port set to be in DHCP mode. Make sure it’s fully initialized (leave 5 min) and then put in the Cat 5E/6 cable to the Hub.
- Now power up the VM hub and you should get a connection. This order only needs to be done the first time you connect your own router to the VM hub.
