I currently have a Hub 4.0 with 500 mb, my wired connection is perfect, but even when i stand next to the router i struggle t get >50mb. I've accepted that the only way to fix this is to get myself a Mesh netwrok. I'm happy to spend whatever it takes to get a Wi-fi network, but don't want to end up throwing good money away when a cheaper option might do the same thing.
I live in an average size 3 bedroom house, my VM hub is located in my entrance hall at the bottom of my stairs.
Should I get a 3 pack Mesh or would a 2 pack be enough?
I've been looking at some options, could you advise if any of these are any good?
1) TP Link M5
2) TP Link M9
3) Netgear Orbi AC3000
4) Netgear Nighthawk Wifi-6
With 4) i do hae an iphone 11 and will be getting a new Macbook Pro M1 soon which i know will be wi-fi 6 comp.
Adam
