Best Ethernet cable
I am wanting to run an Ethernet cable from my hub direct to my PC, which is the best type of cable to use. TIA
  • 4.78K
  • 877
  • 1.26K
Re: Best Ethernet cable
Hello
Any Ethernet cable that is marked Cat 5e or Cat 6 is more than enough going any higher Cat will not make any difference.
Regards Mike
  • 3.54K
  • 569
  • 1.39K
If you're doing a long run of cable with the potential for interference (eg from parallel mains electricity, or passing near fluorescent lights, motors or similar) you would be better of using shielded ethernet, that's Cat 6a or Cat 7.  For the lengths being used in a residential property the extra cost is negligible.
  • 7.54K
  • 593
  • 1.28K
Legend
Totally unnecessary to use Cat7 cable. Some of my house is still wired with good quality AT&T Cat5 cable and it easily achieves 1G even on long runs with no interference. Just make sure you buy good quality cables.
  • 15.68K
  • 1.64K
  • 2.67K
Google is your friend ! 🙂
https://www.techadvisor.co.uk/test-centre/network-wifi/best-ethernet-cables-3671060/
  • 7.54K
  • 593
  • 1.28K
Legend
I prefer to use specialists like https://www.network-cabling.co.uk/store
