@enalty wrote:
The wifi has stopped working in my house and the base light is flashing green, can someone help please?
take a look here and follow the steps
https://www.virginmedia.com/help/virgin-media-what-do-the-lights-on-your-hub-mean
Check the cable connections.
Are wired devices - Ethernet connections OK?
Next try power cycling (power off/back on) the hub
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
