Bad latency and no help
Good afternoon,
Over the past year we have had severe issues with latency and download speeds with hub 3.0.
I have contact virgin a number of times and so far had an engineer our to fit a wifi booster and calibrate the hub.
The issue is still there and when calling up i am told there is nothing they can do and the only option is to leave.(after 48 minute phone call diagnosing)
I am not impressed with the customer service and feel like there is no respect for loyal customers(been with them approx 20 years, virgin/ntl)
Does any1 have a solution before i leave.
I mentioned the new hub 4.0 and they refused any interest and said they can not help me even tho i am on a top package.
Many thanks
  • 24.97K
  • 1.44K
  • 3.18K
Re: Bad latency and no help
Latency measured where?
Are you using a wired or wireless connection?
  • 12.12K
  • 942
  • 1.55K
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Mike Robinson
  • 12.12K
  • 942
  • 1.55K
Can you please
Mike Robinson
Hi mate, cheers for reply.
Bad latency on all devices. Have tested wired and wireless on all consoles and laptops but did not make a difference.
Have been told its a very common issue with hub 3
Many thanks
  • 24.97K
  • 1.44K
  • 3.18K
What are you measuring latency with though?
What tool/software
