MrMMS
  • 5
BT whole home
May sound odd but I have some black spots of signal just outside my house where I have some ring devices so I managed to get some BT whole home discs to pair up. Just curious, do I need to set up via BT app or can I link up via the virgin connect app? And do I need to do anything to my existing hub 3?
Tags (4)
tehwolf
  • 1.56K
  • 253
  • 379
Superfast
Re: BT whole home
you'll have to manage the discs through the BT app.
you should probably disable the wifi broadcast from your hub and connect everything to the disc network - no point in keeping the hub wifi active.
