Message 1 of 5
BT Wole Home WiFi AND New Virgin Hub
I am currently with Plusnet and using BT Whole Home WiFi with a BT Home Hub 6. I am moving to Virgin in the next few days. I am wondering what I have to do to my 6 discs to work with the virgin hub, is it just a matter of resetting the first hard wired disc or do I have to reset the whole system and start each disc again?
  • 5.87K
  • 1.11K
  • 1.55K
Message 2 of 5
Re: BT Wole Home WiFi AND New Virgin Hub
Hello
All you will need to do is to place the hub you receive from Virgunmedia into modem only mode and then you can connect the system up too the hub. https://www.virginmedia.com/help/virgin-media-hub-modem-mode
If you have problems when you get install by all means come back to the forum.
Regards Mike
  • 11.77K
  • 917
  • 1.51K
Message 3 of 5
The easiest thing to do would be put all the components back to factory settings and start from scratch.
Mike Robinson
  • 24.66K
  • 1.42K
  • 3.14K
Message 4 of 5
@DJ_Shadow1966 wrote:
Hello
Regards Mike
BT Whole Home has no routing capabilities so the hub needs to stay in Router Mode
Message 5 of 5
Many thanks for all your help, it was easy to connect Whole Home WiFi to new hub, I did have to to reboot (pulled out and reinserted power plug) disc 1 (has to be hard wired). Everything now OK with all my discs , some minor niggles did occur though:-
Cameras connected to network had to be rebooted (turn off power and restart)
I coudn't work out initially why NAS drives were invisible to my Media Player and Laptop, in a flash of inspiration I wondered if IP address had changed - which it had!  I had to access NAS drives main setup - I didnt change anything but it worked, Laptop sorted itself after reboot.
The only other problem I had was for some reason I could not disable WiFi on the new hub. but I left it on and doesn't seem to cause problems
