BROADBAND ISSUES
I called Virgin to move our hub at a cost of £100 a few months back- we have had some work at home and wanted to move it to the new area of the house. while we we doing the work we got the builders to put in a cat6 network cable so we could have a wireless access point upstairs as we have 3 floors in our house. initially all was well and the access point worked fine and we had really good wifi signal everywhere. then slowly the problems started with it dropping every so often so the hub needed rebooting - a real problem when 4 of you are working from home and on zoom. we also then tried to set up a sonos speakers in separate rooms - the hub didn't like this at all. it played for a few minutes and then dropped completely. we also have ring, adt and hive set up which seems to work ok. however pretty much every day we have to reboot the hub. virgin are not being helpful at all -i am paying for the best broadband package and they can't resolve my issues.
can anyone please suggest what i can do?
  • 25.15K
  • 1.44K
  • 3.2K
Re: BROADBAND ISSUES
Have you ruled out the AP being an issue?
Yes, same issues when the ap is switched off and disconnected
  • 25.15K
  • 1.44K
  • 3.2K
Post the network, upstream and downstream logs from the hubs admin pages
