tylerrhodes
  • 15
Message 1 of 15
BQM test and router status help
so ive ran a BQM test and im not sure what the results mean and ive got my router status stats and im not sure if anything is wrong. Last few weeks i have had latency issues with lag and slow speeds and low upload speeds. Can anyone analyse this for me please?
https://www.thinkbroadband.com/broadband/monitoring/quality/share/8cd4008c6c459846d2960db1f27da21dc6...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/16df195e48ef5b4824eb52aedf94da9b7f7eaea8
tylerrhodes
  • 15
Message 2 of 15
Re: BQM test and router status help
Cable Modem Status Item Status Comments
419000000
Locked
Ranged Upstream Channel (Hz)
60299966
Locked
Provisioning State
Online
tylerrhodes
  • 15
Message 3 of 15
1419000000-1.238256 qam32
2203000000-3.738256 qam9
3211000000-3.738256 qam10
4219000000-3.438256 qam11
5227000000-3.538256 qam12
6235000000-3.238256 qam13
7243000000-338256 qam14
8251000000-2.538256 qam15
9259000000-2.538256 qam16
10267000000-2.738256 qam17
11275000000-2.538256 qam18
12283000000-2.238256 qam19
13291000000-238256 qam20
14299000000-1.538256 qam21
15307000000-1.738256 qam22
16315000000-1.538256 qam23
17323000000-238256 qam24
18363000000-1.438256 qam25
19371000000-238256 qam26
20379000000-1.538256 qam27
21387000000-2.438256 qam28
22395000000-1.540256 qam29
23403000000-1.538256 qam30
24411000000-138256 qam31
1Locked38.9170
2Locked38.92410
3Locked38.61720
4Locked38.62370
5Locked38.61930
6Locked38.92010
7Locked38.9580
8Locked38.9120
9Locked38.6270
10Locked38.9150
11Locked38.950
12Locked38.9130
13Locked38.9630
14Locked38.960
15Locked38.950
16Locked38.940
17Locked38.6210
18Locked38.910
19Locked38.660
20Locked38.6110
21Locked38.9110
22Locked40.3120
23Locked38.980
24Locked38.6100
tylerrhodes
  • 15
Message 4 of 15
16029996654512064 qam1
25370000254512064 qam2
tylerrhodes
  • 15
Message 5 of 15
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
kldJKDHSUBsgvca69834ncxv9
SFID 31661
Max Traffic Rate 230000061
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 31658
Max Traffic Rate 22000061
Min Traffic Rate 0
Max Concatenated Burst 42600
Scheduling Type BestEffort
tylerrhodes
  • 15
Message 6 of 15
01/02/2021 12:16:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/02/2021 12:16:13Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 20:22:7Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 17:03:23noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 15:33:9criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2021 09:51:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 17:42:23Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 17:33:18noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 17:33:2Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 17:21:54noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 17:17:16Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/01/2021 17:12:18Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:02:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 15:49:53criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 15:49:46Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 15:49:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 15:49:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 20.66K
  • 2.2K
  • 3.65K
Message 7 of 15
You only have 2 upstream channels rather than 4 and the power levels are at the top of the recommended range. This could be causing the issue. Can you do this first to start from a blank sheet and see if the missing Up channels re-appear.
___________________________________________
First switch the Hub off for 5 minutes AND unplug it from the mains. Whilst it's off, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box. Then switch it on again and leave 5 minutes
Then do a Hub “pinhole reset” - make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub, and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 10’ to stabilise - dont manually switch it off at any time.
tylerrhodes
  • 15
Message 8 of 15
ive done the pinhole reset multiple times and ive checked the cabling and its finger tight from both the wall side and to the routers side. I had 1 upstream connection before and it went up to 2 if i can remember but i now know it should be 4 Does the BQM show anything in particular? Also what should i do if i only have 2 upstream channels and the power is at the top if ive done the steps please? Thanks for your reply also 🙂
FAM0422
  • 29
Message 9 of 15
I would check the cable is it damaged or old? When you check the connection on wall can you check the outside connection is tight.
Do you have a spare cable coax that you could change and see.
tylerrhodes
  • 15
Message 10 of 15
i could have, this might help. i will try it tomorrow. thanks and ill come back with a follow up 🙂
