  • 15
Message 1 of 16
BQM periods of 100% packet loss and high latency
I've never had a very good, stable or reliable connection with VM, recently had an engineer out to sort out low power levels however lately the connection has been terrible with multiple drops in connectivity throughout the day.  I have a Hub 3.
Whilst trying to work from home we experience frequent drops in connection, yes its WiFI not wired using a wired connection is not practical.  We frequently experience drops for a period a couple of minutes where the WiFI signal is reported as strong but multiple device experience no internet connectivity or extremely slow connectivity.  Then magically full speed returns after a short blip.
I see the same behaviour on my WiFi extender too, it reports a very string WiFI signal with the Hub but no internet connectivity.  I don't believe its due to the WiFi signal.
I'd previously set up a BQM and pretty much every day there are large periods of time where there is 100% packet loss and huge latency spikes.
Here's the BQM from Friday 13th which was a particularly bad day for connectivity:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/5611f48512a72216b61d380279e216e339...
and here's a view over the weekend too:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/c5c8baa7c283cc50d0495972a9af2fa743...
The reliability of the connection is becoming really annoying, perhaps I'm paranoid but it seems to get worse in bad weather.
Any suggestions would be appreciated.
Steve
  • 15
Message 2 of 16
Re: BQM periods of 100% packet loss and high latency
For completeness here's the info from my Hub too:
1235000000240256 qam13
22430000001.740256 qam14
32510000001.740256 qam15
42590000001.440256 qam16
52670000001.438256 qam17
62750000001.540256 qam18
72830000001.240256 qam19
82910000001.540256 qam20
92990000001.940256 qam21
103070000000.738256 qam22
113150000001.438256 qam23
123230000001.538256 qam24
133310000000.738256 qam25
14371000000138256 qam26
153790000000.938256 qam27
163870000000.738256 qam28
17395000000038256 qam29
184030000000.238256 qam30
194110000000.738256 qam31
20419000000-0.238256 qam32
21427000000038256 qam33
22435000000-0.238256 qam34
23443000000-0.938256 qam35
24451000000-0.740256 qam36
1Locked40.3750
2Locked38.92630
3Locked40.32660
4Locked40.31660
5Locked38.92050
6Locked40.32230
7Locked38.95570
8Locked40.35110
9Locked40.312290
10Locked38.919350
11Locked38.910970
12Locked38.912530
13Locked38.915530
14Locked38.93420
15Locked38.93220
16Locked38.611050
17Locked38.9134014
18Locked38.968716
19Locked38.9151131
20Locked38.9129186
21Locked38.9766132
22Locked38.9464143
23Locked38.943584
24Locked40.3360
76
13940000042.5512064 qam6
24620000043512064 qam5
32580000041512064 qam8
43260000041.5512064 qam7
2ATDMA0010
3ATDMA0020
4ATDMA0040
  • 15
Message 3 of 16
And the network log which is always full of errors and warnings:
13/11/2020 04:05:39ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 05:48:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 19:10:5noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 20:43:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 16:05:39ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 12:42:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 04:45:41ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 18:53:11noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 16:03:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 15:19:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 14:25:41ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 19:38:36criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/10/2020 02:25:41ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 00:18:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 14:25:40ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/10/2020 14:13:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 17:27:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 12:27:35Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 18:04:34criticalNo Ranging Response received - T3 time-out;CM-MAC=1**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 17:42:53Warning!RCS Partial Service;CM-MAC=1**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 15
Message 4 of 16
Here's some more BQM's showing the blocks of packet loss
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a31d2663adc9948f1156a9b7890863482f...
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e8e20addc42bbb4f750a544fde51d67e57...
What's the issue with the frequent blocks of packet loss?  These seem to coincide with poor or dropped connectivity.
Really frustrated with the poor reliability of this service.
  • 15
Message 5 of 16
Today my BQM is showing 100% packet loss for the entire day.  My IP hasn't changed.
  • 11.74K
  • 915
  • 1.51K
Message 6 of 16
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything is OK, can you log into the Hub Settings and set your Firewall up to the same as below ...
Hub-3-Firewall
Mike Robinson
  • 24.64K
  • 1.42K
  • 3.14K
Message 7 of 16
Has your connection been of the entire day?
If not just reboot the hub as its prone to dropping ICMP requests for no reason.
  • 15
Message 8 of 16
The connection is up, although continues to suffer drop outs at points through the day (please see the first post) but for the last few days the BQM is showing as completely red.
All connections are tight, there are no reported local issues and the firewall is configured correctly.
Its just an unreliable service.
  • 24.64K
  • 1.42K
  • 3.14K
Message 9 of 16
Again the red blocks on the BQM is the hub just being dumb - reboot it and it will start reporting again.
  • 15
Message 10 of 16
Any advice regarding the constant drops in connection?
