forumarchive,nothingtosee,
Skovde
  • 11
Message 1 of 20
BMQ test - Hub 4.0
Hi All,
Since about Nov20 I have been having issues with the internet, randonmly losing connection. I had the Hub 2.0, which VM said was the cause of the problem. They sent a Hub 3.0 which I set up, again having the same issues - losing connection daily between 10.45 and 11.15 pm and for a couple of minutes every hour.
On my numerous calls to their tech support I have been given several explanations, from signal loss to too many devices (100MB line with 4 tables, 2 laptops and 3 phones, plus a couple of Alexas and 1 smart TV).
Finally a technitian came yesterday, who installed a Hub 4.0 - yet the same problem remains.
I have the following BQM  -
https://www.thinkbroadband.com/broadband/monitoring/quality/share/41234262a96439fdb1216c3d6d703fa930...
I would appreciate your thoughts.
gary_dexter
  • 28.7K
  • 1.75K
  • 3.74K
Message 2 of 20
Re: BMQ test - Hub 4.0
Post the network, upstream and downstream logs from the hubs admin pages back here as text
tehwolf
  • 1.52K
  • 243
  • 367
Superfast
Message 3 of 20
doesn't look like a typical overutilisation issue, which is probably a good thing 🙂
the spikes overnight seem to be every hour somewhere between :30 and :45 - it's too regular to be something random.. either a fault at the CMTS end of the connection that manifests in the hourly spike, or potentially something on your local network that's doing something every hour or so that's causing a problem for the connection?
someone who knows more about the wider VM network than i do may be able to shed some more light on the first assumption... as for the second based on what you've said is connected to the network, i can't offer up anything obvious I'm afraid 😕
it;s probably worth posting a full set of logs from your hub - browse to your hub on  http://192.168.0.1 - log in and browse to Advanced - you're looking for "Router Status" in there somewhere..  copy/paste the tables from the Upstream, Downstream and Network Log tabs back to this thread - you'll need multiple posts for this, the info wont all fit into a single one..
gary_dexter
  • 28.7K
  • 1.75K
  • 3.74K
Message 4 of 20
I used to get the regular hourly spikes on my Hub4 when in Router Mode that disappeared when changing to Modem Mode - it was talked about on here (although unconfirmed) that the hourly spikes are from SamKnows running an automated hourly speedtest on the Hub4 for "reporting purposes"...
JitteryPinger
  • 1.65K
  • 183
  • 327
Super solver
Message 5 of 20
I've been noticing some spiking going on with a Hub 4 I have running in Modem Mode, see below.
If I've helped please let me know 🙂 Matt
A 10+ Year Virgin Media veteran, been here through the Up's and the Down's and Down's....
Vodafone 5G EE BQM Hub 4 BQM Hub 3 BQM Hitron CGNV4 BQM
Technical Support - AV & Networking - Customer Service - Finance - Culinary - Construction
Skovde
  • 11
Message 6 of 20
3.0 Upstream channels
139400000415120 KSym/sec64QAM9
24620000041.35120 KSym/sec64QAM8
32580000040.55120 KSym/sec64QAM11
43260000040.85120 KSym/sec64QAM10
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
Tags (1)
Skovde
  • 11
Message 7 of 20
3.0 Downstream channels
30402750000-1.538.6QAM25630
11387500002.638.6QAM2561
21467500001.938.6QAM2562
31547500001.639QAM2563
41627500001.338.6QAM2564
51707500001.138.6QAM2565
6178750000138.6QAM2566
71867500000.939QAM2567
81947500000.939QAM2568
92027500000.938.6QAM2569
102107500000.838.6QAM25610
112187500000.938.6QAM25611
122267500000.839QAM25612
132347500000.538.6QAM25613
142427500000.439QAM25614
152507500000.338.6QAM25615
162587500000.139QAM25616
17266750000-0.439QAM25617
18274750000-0.738.6QAM25618
19282750000-0.338.6QAM25619
20290750000-0.239QAM25620
21298750000-0.238.6QAM25621
22306750000-0.738.6QAM25622
23314750000-0.938.6QAM25623
24322750000-1.338.6QAM25624
25330750000-1.238.6QAM25625
26370750000-1.237.6QAM25626
27378750000-1.637.6QAM25627
28386750000-1.438.6QAM25628
29394750000-1.637.6QAM25629
31410750000-2.237.6QAM25631
Tags (1)
Skovde
  • 11
Message 8 of 20
30Locked38.60537700
1Locked38.60537700
2Locked38.60537700
3Locked38.98326100
4Locked38.60537700
5Locked38.60537700
6Locked38.60537700
7Locked38.98326100
8Locked38.98326100
9Locked38.60537700
10Locked38.60537700
11Locked38.60537700
12Locked38.98326100
13Locked38.60537700
14Locked38.98326100
15Locked38.60537700
16Locked38.98326100
17Locked38.98326100
18Locked38.60537700
19Locked38.60537700
20Locked38.98326100
21Locked38.60537700
22Locked38.60537700
23Locked38.60537700
24Locked38.60537700
25Locked38.60537700
26Locked37.63627600
27Locked37.63627600
28Locked38.60537700
29Locked37.63627600
31Locked37.63627600
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33964K1880QAM4096759
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33Locked39-4.913769000
Skovde
  • 11
Message 9 of 20
Thu 01/01/1970 00:01:243No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 23/02/2021 17:52:535MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Skovde
  • 11
Message 10 of 20
And latest BQM
https://www.thinkbroadband.com/broadband/monitoring/quality/share/41234262a96439fdb1216c3d6d703fa9300f7506-23-02-2021
