on 11-10-2023 10:05
This is a weird one and somewhat unexpected.
I've just upgraded from M500 to 1Gig and plugged in the new Hub 5 to replace the existing Hub 3 in my lounge.
I use 4 Asus Mesh routers to get coverage around the house (Victorian with high ceilings and thick walls) and was used to getting 400-500+ in my "office" using my PC over Wifi and pretty much 300+ over Wifi in most places using other devices
So I put the Hub 5 in place, set it to modem mode, rebooted my Asus routers and my Wifi speeds have dropped. the BEST I've seen in the office on my PC is 300 (against the 400 - 500+ I used to see) and in my lounge on my phone the best I've seen is 420 rather than the (490 - 540) I used to.
Meanwhile the Hub 5 reckons it's getting over 1Gig incoming.
Just to reiterate; the only piece of equipment which has changed is VM Hub from the old 3 to the new 5. Everything else is the same.
Anybody had this problem before and have any suggestions?
Cheers
Answered! Go to Answer
on 11-10-2023 10:11
Out of interest which RJ45 port are you using on the Hub5? One of them is 2.5Gb and I wonder if auto negotiation is causing an issue?
on 11-10-2023 10:11
on 19-10-2023 11:30
I was using the 2.5Gb but swapped to one of the 1Gb which seems to have resolved the issue
