Donkyle
  • 11
Arrows going different directions flashing red
Im wondering if anyone can help me, i reset my modem because the internet was having connection issues but when i turned it back on and its connecting everything im getting red flashing arrows. Ive never had that one before.
Hurst10
Re: Arrows going different directions flashing red
Hi DonKyke,
Is the Modem in question a Hub 3?.
The flashing arrows is usually a connection to the server, Red arrows means that an issue has happened.
Try doing a restart of the Hub, should this fail check any connections in the rear of the hub and remove any Ethernet connections. Then try another restart.
Usually speaking the red arrows appear when the Hub has failed to update or had an issue updating. The Hub will tend to restart at a later time and try to fix itself.
Many Thanks
Hursty
