Manni1184
Message 1 of 9
Arlo Wireless Camera problems with hub3
Hello, i just purchased the ARLO wireless camera, however it keeps saying software update and i cannot live stream the feed
Now here's the interesting bit..........i took the camera round to my parents who also have virgin wifi 100mb hub 2 and there is no issues, works perfectly
however my hub3 350mb speed there is! anyway round this? i thought it would be ARLO software issue but its obviously a virgin hub problem
  • 1.82K
  • 179
  • 427
vircom
Super solver
Message 2 of 9
Re: Arlo Wireless Camera problems with hub3
Have you given the 2.4 and 5G bands a seperate SSID?
Try rebooting the hub by powering off and back on after a few minutes?
If connecting at 2.4G, make sure the hub is using a channel bellow 11?
Try downloading a wifi analyser to your mobile and look for congestion caused by other peoples wifi.
Could there be interference from things like baby monitors etc. This would not show on wifi monitor?
  • 12.75K
  • 400
  • 731
Forum Team (Retired) Heather_J
Message 3 of 9
Hello Manni1184,
Thanks for joining us on the Forum 😄
Sorry to hear that you're struggling to connect your cameras. Has the above advice helped at all? We might need to do some port forwarding to enable access for the devices.
Let us know if you still need help with this,
Take care.
Heather_J
Manni1184
Message 4 of 9
Hello I got.the same.issue with a replacement camera again, but I left it alone for 2 days and now it's working,baffled but greatful
  • 12.75K
  • 400
  • 731
Message 5 of 9
Hey Manni1184,
Thanks for letting me know 😄
Good to know this has been resolved.
We're always here if you need us,
Take care.
Heather_J
Manni1184
Message 6 of 9
heather im having problems again, had a replacement sent out, work with my parents one fine hub 2 but not with my hub 3! can anyone help ugghhh
Manni1184
Message 7 of 9
can someone help me reconfigure my router? i do have wi fi issues from the look of it as it keeps going offline and back on
  • 10.32K
  • 281
  • 591
Forum Team (Retired) Emma_E
Message 8 of 9
Hi Manni1184,
Thanks for getting back in touch, I am sorry to see you have continued to have trouble with your connection.
I have taken a look and your downstream power levels are too low. Which can cause wireless issues.
I would like to get an engineer out to take a look at this for you. I will pop you a Pm to get this arranged.
Keep an eye out for the Purple Envelope, top right hand corner.
It may also help to separate your WiFi modes.
Access your Hub by navigating to 192.168.0.1
Login with the default login info (on base of Hub) unless you've already updated it.
Go to Advanced Settings > Wireless > Security
Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID) and the Wifi password (network key).
Repeat for the Wireless Frequency 5GHz and click on Apply changes.
Speak to you soon.
Emma
  • 22
Bazzamer
Message 9 of 9
Hi, I have the hub3 and also have problems with it going offline, I think the answer is to filer things, i mean keep the camera on 2.4ghz and stop it going onto the 5ghz, the same with a laptop, keep it on 5ghz and deny access to 2.4ghz, the speed increase is really good. But as yet have not solved camera going offline, as i think it tries to use 5ghz and fails, so it goes offline, hope it helps.
Bazzamer
