Are my downstream and upstream power levels within spec?
Gapti
HI I have had an issue with my broad band which caused me not to beable to get on some websites using the broadband but I can access them on my 4g network. I had the modem changed by a tech and now the website still isnt coming up and during online gamming I am having massive ping spikes which cause the game to be not playable on line. Could you look at these upload and download logs to see if they are within the spec please.
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
331000000
2.5
38
256 qam
25
2
203000000
1.7
38
256 qam
9
3
211000000
1.5
38
256 qam
10
4
219000000
1.5
38
256 qam
11
5
227000000
1.5
38
256 qam
12
6
235000000
1.4
38
256 qam
13
7
243000000
1.2
38
256 qam
14
8
251000000
0.7
38
256 qam
15
9
259000000
0.9
38
256 qam
16
10
267000000
1.2
38
256 qam
17
11
275000000
1.5
38
256 qam
18
12
283000000
1.9
38
256 qam
19
13
291000000
2
38
256 qam
20
14
299000000
2.4
38
256 qam
21
15
307000000
2
38
256 qam
22
16
315000000
2.2
38
256 qam
23
17
323000000
2
38
256 qam
24
18
339000000
2.2
38
256 qam
26
19
347000000
2.5
38
256 qam
27
20
355000000
2.4
38
256 qam
28
21
363000000
3
38
256 qam
29
22
371000000
3
38
256 qam
30
23
379000000
3
38
256 qam
31
24
387000000
2.9
38
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
38.6
50
0
2
Locked
38.9
15
0
3
Locked
38.6
13
0
4
Locked
38.6
9
0
5
Locked
38.6
16
0
6
Locked
38.6
20
0
7
Locked
38.6
20
0
8
Locked
38.6
22
0
9
Locked
38.9
40
0
10
Locked
38.6
23
0
11
Locked
38.6
28
0
12
Locked
38.6
25
0
13
Locked
38.6
36
0
14
Locked
38.6
38
0
15
Locked
38.9
46
0
16
Locked
38.6
46
0
17
Locked
38.9
34
0
18
Locked
38.6
51
0
19
Locked
38.9
51
0
20
Locked
38.6
67
0
21
Locked
38.6
61
0
22
Locked
38.6
55
0
23
Locked
38.9
41
0
24
Locked
38.6
45
0
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
49600000
46.5
5120
64 qam
1
2
43100000
46.3
5120
64 qam
2
3
30100000
46
5120
64 qam
4
4
36600000
46
5120
64 qam
3
5
23600000
46.3
5120
64 qam
5
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
1
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
5
ATDMA
0
0
0
0
Time
Priority
Description
06/06/2023 23:06:50
critical
06/06/2023 20:53:14
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2023 20:51:39
Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:41
critical
06/06/2023 20:22:15
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2023 20:13:41
critical
06/06/2023 20:12:44
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2023 20:08:18
critical
06/06/2023 19:49:41
critical
06/06/2023 18:32:48
critical
06/06/2023 18:04:13
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/06/2023 17:59:11
critical
06/06/2023 17:51:12
Warning!
06/06/2023 17:51:4
Warning!
06/06/2023 17:51:1
Warning!
06/06/2023 17:50:30
critical
06/06/2023 17:26:22
Warning!
06/06/2023 17:10:43
critical
06/06/2023 16:41:48
Warning!
06/06/2023 16:38:57
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10 REPLIES 10
Nothing wrong with the power levels.  Have you setup a BQM to monitor and record your circuit?
How are you connected, wired or wireless ?
Hi Adduxi,
Have you setup a BQM to monitor and record your circuit? ... How do I do this ?
I am wired into the modem.
www.thinkbroadband.com/ping  It's fairly straightforward and the site has lots of help on setting it up.  Most users on here have one running.  VM would also ask you to do so for diagnostics etc.
Adduxi I have created a BQM but its showing 100% packet loss. I am using a hub 3 and cannot see where to enable the following below.
  1. Finally, ensure the tickbox is checked after 'Respond to ICMP echo requests sent to WAN IP' and click 'Apply'.
Can you help?
Don't know for sure, I only ever use VM Hubs in modem mode.  I'll guess it's in the Firewall section somewhere?
Gapti
Here is the graph so far My BQM
What do you guys think ?
carl_pearce
Community elder
Some spikes, however looks normal for a VM line.
Here's mine as an example:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/f456cb37eb5964be55ad4b06a2cd7bb860...
Hi Gapti,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the issues you've been having with your Broadband service.
Are you happy to confirm any of the websites you have been having this issue on?
So we can test these on our side.
^Martin
HI Martin,
My internet has settled down latley and the website is fully working now. The website was https://yourfpv.co.uk/
