Share your upstream and downstream stats
Virgin Media Hub 5 and Hub 5x settings
Just follow these simple steps:
Enter 192.168.0.1 into the address bar of your browser, enter your password and the settings page will then load
Under Modem status overview you can see the status of your modem and the devices that are currently connected
Other tips
For more details about the Hub, select Admin, and then select Info. Here you can see hardware and software versions, how long the Hub has been turned on and connected to the Virgin Media network, as well as the LAN and WAN IP details
To see more details about the Hub’s connection to the Virgin Media network, select Advanced Settings, in the Tools section, select Network Status
