on 26-10-2022 11:22
I have had broadband installed into my new property and for the last 20 days I have had nothing but connection issues.
I have made a number of phone calls to virgin which resulted in an engineer coming out to tell me my levels are bad and it must be a cabint issue. As he is install there is nothing he can do. He also told me since I am the only one in the cabinet that the issue will be bottom of the list.
Daily my connection drops I have been tracking using think broadband since I have been reading simalar issues on these forums.
The main reason for my post is a hope that somebody from virgin picks this up and can help me work from home. 20 Days since I got the product and every day there has been drop outs.
Can anyone help?
on 26-10-2022 14:52
on 26-10-2022 15:40
1 | 331000000 | 2.6 | 40 | QAM 256 | 25 |
2 | 179000000 | 3.4 | 40 | QAM 256 | 6 |
3 | 187000000 | 3.6 | 40 | QAM 256 | 7 |
4 | 195000000 | 3.7 | 40 | QAM 256 | 8 |
5 | 203000000 | 3.6 | 41 | QAM 256 | 9 |
6 | 211000000 | 3.6 | 40 | QAM 256 | 10 |
7 | 219000000 | 3.5 | 41 | QAM 256 | 11 |
8 | 227000000 | 3.3 | 40 | QAM 256 | 12 |
9 | 235000000 | 3.4 | 40 | QAM 256 | 13 |
10 | 243000000 | 3.3 | 40 | QAM 256 | 14 |
11 | 251000000 | 3.1 | 41 | QAM 256 | 15 |
12 | 259000000 | 2.9 | 41 | QAM 256 | 16 |
13 | 267000000 | 2.9 | 41 | QAM 256 | 17 |
14 | 275000000 | 3 | 41 | QAM 256 | 18 |
15 | 283000000 | 3.2 | 41 | QAM 256 | 19 |
16 | 291000000 | 3.3 | 41 | QAM 256 | 20 |
17 | 299000000 | 3.2 | 41 | QAM 256 | 21 |
18 | 307000000 | 3.1 | 40 | QAM 256 | 22 |
19 | 315000000 | 3 | 40 | QAM 256 | 23 |
20 | 323000000 | 2.8 | 40 | QAM 256 | 24 |
21 | 339000000 | 2.4 | 40 | QAM 256 | 26 |
22 | 347000000 | 2.2 | 40 | QAM 256 | 27 |
23 | 355000000 | 2.2 | 40 | QAM 256 | 28 |
24 | 363000000 | 2.3 | 41 | QAM 256 | 29 |
25 | 371000000 | 2.4 | 41 | QAM 256 | 30 |
26 | 379000000 | 2.4 | 41 | QAM 256 | 31 |
27 | 387000000 | 2.2 | 41 | QAM 256 | 32 |
28 | 395000000 | 2.1 | 41 | QAM 256 | 33 |
29 | 403000000 | 2 | 41 | QAM 256 | 34 |
30 | 411000000 | 1.9 | 41 | QAM 256 | 35 |
31 | 419000000 | 1.9 | 41 | QAM 256 | 36 |
1 | Locked | 40 | 18465 | 2905 |
2 | Locked | 40 | 1236232 | 17327 |
3 | Locked | 40 | 71511 | 8832 |
4 | Locked | 40 | 11374 | 5159 |
5 | Locked | 41 | 9382 | 5347 |
6 | Locked | 40 | 7765 | 3075 |
7 | Locked | 41 | 8383 | 3996 |
8 | Locked | 40 | 6484 | 2152 |
9 | Locked | 40 | 6358 | 1606 |
10 | Locked | 40 | 6077 | 1690 |
11 | Locked | 41 | 4511 | 1254 |
12 | Locked | 41 | 4548 | 828 |
13 | Locked | 41 | 4753 | 1243 |
14 | Locked | 41 | 4588 | 826 |
15 | Locked | 41 | 4303 | 802 |
16 | Locked | 41 | 3966 | 1198 |
17 | Locked | 41 | 3581 | 1414 |
18 | Locked | 40 | 3212 | 830 |
19 | Locked | 40 | 4223 | 1114 |
20 | Locked | 40 | 3337 | 866 |
21 | Locked | 40 | 3440 | 714 |
22 | Locked | 40 | 3461 | 670 |
23 | Locked | 40 | 2554 | 542 |
24 | Locked | 41 | 2642 | 634 |
25 | Locked | 41 | 3118 | 668 |
26 | Locked | 41 | 3180 | 1131 |
27 | Locked | 41 | 3124 | 1357 |
28 | Locked | 41 | 3264 | 1189 |
29 | Locked | 41 | 2800 | 1236 |
30 | Locked | 41 | 2617 | 393 |
31 | Locked | 41 | 2513 | 447 |
0 | 49600000 | 50.3 | 5120 | QAM 64 | 1 |
1 | 43100000 | 50 | 5120 | QAM 64 | 2 |
2 | 36600000 | 49.8 | 5120 | QAM 64 | 3 |
3 | 30100000 | 49.5 | 5120 | QAM 64 | 4 |
4 | 23600000 | 49.3 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 220 | 0 | 0 |
1 | ATDMA | 0 | 220 | 0 | 0 |
2 | ATDMA | 0 | 220 | 0 | 0 |
3 | ATDMA | 0 | 220 | 0 | 0 |
4 | ATDMA | 0 | 220 | 0 | 0 |
26-10-2022 15:29:35 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:35 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:31 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
26-10-2022 15:29:26 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:26 | warning | Dynamic Range Window violation |
26-10-2022 15:29:26 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:25 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:19 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:17 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:14 | critical | DHCP FAILED - Discover sent, no offer received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:10 | notice | Honoring MDD; IP provisioning mode = IPv4 |
26-10-2022 15:29:01 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:01 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:29:01 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:58 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:58 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:54 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:54 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:49 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:46 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:46 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:43 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:43 | notice | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:42 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 6 13 20 21 23 24 26 27 28 29 30 31 32 33 34 35 36; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:42 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:37 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:37 | critical | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
26-10-2022 15:28:34 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 26-10-2022 15:44
https://www.thinkbroadband.com/broadband/monitoring/quality/share/7f1cb597312bfd33d547dca368e9945239d8bcb8
26-10-2022 15:57 - edited 26-10-2022 16:00
Bqm showing frequent short disconnects. The errors are odd - T2 up errors are new to me and powers are on the high side. The post RS errors may be a concern too - and the Logs look a right mess. Will need a VM person to comment (I have flagged for one) but can you start from a clean sheet and do this.
______________________________________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes
When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. If they do (particularly the postRS and T ones) you have a problem (noise) that only a Tech visit will sort.
on 26-10-2022 16:27
Hey, thanks for the advice. The engineer that came out replaced some ends both outside, inside and moved me in the cabinet. My log files are like this daily and I have been monitoring for the past 10 days and logging manually in onenote.
I have done all the pin hole resets etc that they say you should do. VM egineer said its a network issue most likley at the cabinet and as I am the only person on the cabinet I wont be a priority. Swiftly left with will log it with Network team. AKA fobbed off.
All I do is phone VM every time it goes down and complain!
I am hopefull somebody can pick this up here and somehow get my service to behave itself.
on 26-10-2022 16:57
Hi Jobbymaster,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
We're sorry to hear you're having an issue with your broadband connection disconnecting.
Checking things this end, some of the downstream power levels are a little to high. There are some other errors showing too which will need addressing.
We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you. I just need to confirm the address to ensure we are booking the visit on the correct account.
I have sent you a private message regarding this. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
on 26-10-2022 17:39
Hi Jobbymaster,
Thanks for coming back to me via private message.
I have booked you in for the next available appointment. To view this please sign in to My Virgin Media here: My VM. Once logged in, scroll down to Orders & appointments then click on View your orders. You can also view this in the My VM app. If you have any issues with accessing your account or unable to see your visit after 24hours, please do let us know and we’ll pop you another message to pass data protection and then confirm the appointment details.
Just to confirm, there will be no charge for this visit unless:
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure that someone over the age of 18 is at the property for the time the engineer is there. If the appointment is unsuitable or if anyone living at your property has tested positive for Coronavirus, has been asked to self-isolate or has flu-like symptoms then please reschedule the appointment on the same link. If you do miss the appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment so it is important to reschedule if needed.
Lets us know how the appointment goes.
Take care.
on 02-11-2022 11:22
Just an update on my ongoing issues for the last 4 weeks.
I have had 3 engineers come out and all have said its a cabinet issue as levels drop there and network should fix it. I am the only person in the cabinet. I have been moved multiple times inside the cabinet which makes the issue worse.
Who are these network guys? Do they contact me that they are fixing the problem? Egineer said that they would fix it in background, most likley an excuse to get out the house as they are unable to fix.
Close to giving up and moving to another ISP after 4 weeks of a service that is not stable.
Once it drops again today, I am going to call the support again and see what they spin this time.
on 03-11-2022 08:17
I had network call yesterday and change something on network side. After about 30 mins from that phone call the same thing happend. An egineer then turned up later on that evening and swapped out my router as they are saying levels look fine.
Lets see how today goes......already noticed a drop out when i signed in for work.
[url=https://www.thinkbroadband.com/broadband/monitoring/quality/share/1257b46be1debe387a3dc720ed9e8c35f8... Broadband Ping[/url]
