  • 6
Message 1 of 12
Amazon echo not connecting
Amazon echo not connecting to amazon WiFi but will connect to virgin WiFi, keeps advising WiFi not set up on this device any suggestions
  • 20.96K
  • 1.13K
  • 2.7K
Message 2 of 12
Re: Amazon echo not connecting
Amazon WiFi?
  • 6
Message 3 of 12
I need to go to my WiFi thfn the amazon network should appear to press connect but sometimes shows connected then says no Internet access
  • 20.96K
  • 1.13K
  • 2.7K
Message 4 of 12
Are you setting a new echo up?
The Amazon WiFi is only for setting up a new device.
  • 1.8K
  • 62
  • 735
Super solver
Message 5 of 12
Don't see the problem here.   If it connects to VM wi-fi, that is what you want it to do.  If there is an Amazon connectoid (setting), simply delete it and connect via VM.  The notification will then disappear.  Set your VM connection as default on the Echo Dot.  It can't connect to something that doesn't exist, hence the notification.
https://www.alphr.com/smart-home/1007818/how-to-setup-amazon-echo-setup-wi-fi-problems
The only winning move is not to play.
No system is 100% secure
Ridicule is nothing to be scared of - Adam Ant
The only thing constant - is change. Chris Evans
The internet is a series of tubes
Windows Update isn't rocket science - if it were, it would work.
Unlike Monty Python, spam is never off.
  • 6
Message 6 of 12
Just to confirm after it is set up through vm, I go to my settings and delete amazon?
  • 6
Message 7 of 12
Yes brand new
  • 20.96K
  • 1.13K
  • 2.7K
Message 8 of 12
You only connect to the amazon WiFi once when going through the setup process on the Alexa app.
Its not needed thereafter.
  • 6
Message 9 of 12
I get connected to my WiFi the amazon comes up connected then advises no Internet access which confuses me, so the speaker works but not with  my voice. Device says not connected to wifi
  • 20.96K
  • 1.13K
  • 2.7K
Message 10 of 12
During the setup process once connected to the amazon WiFi you go back to the app and finish off the setup and part of that setup is connecting it to your home WiFi connection.
