  • 13
Sukie46
Air print not working
After no WiFi an engineer came out, fiddled and rebooted router, but now my HP printer AirPrint feature won’t work. I can only print via usb.
I reinstalled and it appeared for seconds, then no printer found.
Any ideas?
thanks
  • 1.07K
  • 52
  • 143
MikeRobbo
Knows their stuff
Re: Air print not working
Try this, it refines the wifi setup, it may help it may not but is worthwhile doing for your wifi management.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name > Add 5 to the 5 GHz Channel name > Click ‘Apply Changes’
Log out of the Hub.
You will need to reconnect all you WiFi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
  • 435
  • 26
  • 43
Hi Sukie46, thanks for posting.
Sorry to hear you're having issues with connecting your printer via WiFi.
Have you tried the advice given by MikeRobbo?  If so has it resolved your issue?
Lee_R
  • 13
Sukie46
Hi, I did try but not really sure how to do it. 😞
  • 435
  • 26
  • 43
I am sorry Sukie46.
Can I ask if you've tried 'forgetting the router' on your printer?  I know you've probably already tried the next one, but can you confirm you have held down the WPS button on the hub (if it's a Superhub 3) to enable your printer to find the hub?  Also is it possible to take your printer back to factory settings and then try to connect to your hub?
Lee_R
  • 13
Sukie46
Hi Lee, after re setting everything over the weekend I’ve managed to find my printer wirelessly.
Thanks for your assistance, unsure why is stopped as it’s been working fine for several months.
Sue.
