Afternoon packet loss issues
wassapp
I am experiencing consistent packet loss issues on an afternoon and evening. I accept it's pretty standard (due to more people and neighbours being online) but it's getting to a stage where I'm having to cram work and calls into the morning as the afternoon is becoming unusable.
I use a Hub 3 in modem mode, 125mb which should be upgraded to 250 via 02 volt but virgin and O2 don't seem to be able to sort).
Here is yesterday's graph, I'd appreciate any ideas or feedback on how to improve things.
8 REPLIES 8
Lets see the hub connection data - an you do this...
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
Carley_S
Hi @wassapp
Welcome to the community forums
Sorry to hear you're having issues with your broadband during the afternoon's and evenings.
I have taken a look at our side and can see some areas of concern that I have raised to the team to investigate further to see if this maybe causing your issue.
Other than above there are no issues on your hub's spec and all look within good range. Are you able to provide a live link to your BQM this will help us to support further?
You also mention about VOLT benefits not being applied, does your online account show you that you're still on a M125 package? If not, and it does show a V250 package does your physical speed at the router not show speed within your minimum rage for 250mbps?
Here to help 🙂
Virgin Media Forums Agent
Carley
https://www.thinkbroadband.com/broadband/monitoring/quality/share/create/921e0a8d9dca834df0cb02131f9...
Here is the live BQM (I think). The VOLT issue was resolved by the customer team.
ChannelFrequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
13310000001.940256 qam25
22670000001.740256 qam17
32750000001.540256 qam18
42830000001.740256 qam19
52910000001.540256 qam20
62990000001.940256 qam21
7307000000243256 qam22
83150000001.940256 qam23
93230000001.940256 qam24
103390000001.240256 qam26
11347000000140256 qam27
123550000000.940256 qam28
133630000000.940256 qam29
143710000000.740256 qam30
153790000000.740256 qam31
163870000000.740256 qam32
173950000000.540256 qam33
184030000000.540256 qam34
194110000000.740256 qam35
204190000000.240256 qam36
21427000000040256 qam37
224350000000.440256 qam38
234430000000.440256 qam39
244510000000.240256 qam40
1Locked40.940
2Locked40.970
3Locked40.940
4Locked40.970
5Locked40.9110
6Locked40.960
7Locked43.360
8Locked40.330
9Locked40.940
10Locked40.950
11Locked40.300
12Locked40.950
13Locked40.940
14Locked40.3120
15Locked40.940
16Locked40.9190
17Locked40.950
18Locked40.950
19Locked40.340
20Locked40.9130
21Locked40.3140
22Locked40.360
23Locked40.950
24Locked40.900
13660001741.8512064 qam11
22359998640.3512064 qam13
33010000041.8512064 qam12
44310000941.8512064 qam10
54960000041.8512064 qam9
3ATDMA0000
4ATDMA0000
5ATDMA000
0
30/11/2023 20:39:49noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/11/2023 20:39:20Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/11/2023 18:12:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/11/2023 16:22:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/11/2023 16:22:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2023 23:41:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2023 04:22:24noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/11/2023 04:22:24ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/11/2023 10:24:31criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2023 16:22:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/11/2023 16:22:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/11/2023 01:36:35criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2023 04:22:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/11/2023 04:22:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2023 04:45:7criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2023 16:22:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2023 16:22:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2023 00:18:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2023 04:22:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2023 04:22:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Hello John, sorry I missed this message.
Thanks very much for the advice.
I've done as you suggested. Is it just a case of wait and see what VM say now?
Hi wassapp
Thank you for providing that.
All the ranges on our side look okay but we will continue to monitor this.
That BQM link doesn't take us to the live graph unfortunately.
Instructions for posting BQM Link:
  • Under your BQM graph are two links in red.
  • Click the lower link (Share Live Graph) then click generate.
  • Copy the text in the Direct Link box, beware, there may be more text than you can see.
  • On here click the Link icon (2 links chain to the left of the camera icon)
  • In the URL box paste the link you copied and then click OK.
(This is the link you can hyperlink where it says broadband quality monitor - https://www.thinkbroadband.com/broadband/monitoring/quality)
Looking forward to your reply so we can help.
Vikki - Forum Team
