Message 1 of 5
Advice on Wifi Router
Hi All,
Need some advice please for a suitable router to use with the Super hub 3. As you all know the WiFi with this Hub isn't the best.
I've been sent a set of powerline extenders from Virgin as the WiFi signal especially in the kitchen is pretty poor. I set them up as instructed but it actually made the Wifi signal in the whole house terrible so I disconnected and everything it's back to normal.
So my next option is to get a new Router and put the Hub into Modem mode, my budget isn't great about £70.00 to £80.00.
Can you please suggest a couple of Routers in that price bracket?
  • 30
Message 2 of 5
Re: Advice on Wifi Router
Just to forewarn you, I have tried 2 TP Link routers - both slightly different, and both tested in my bros' home, and both did not work, infact my wifi got really really bad.
I don't know why.
I have invested in a more expensive router, but I am reluctant to open the box and use it, as I suspect there is something wrong with my internet altogether, as now I am having issues even with an ethernet cable.
Good luck!  I bought an Asus router btw - they have models in your price range.
Kristina
Message 3 of 5
Hi David,
To be fair all my hardwired stuff is fine. Its just the WiFi.
I've seen this Model the ASUS RT-AC85P is this the one you have got?
  • 20.96K
  • 1.14K
  • 2.7K
Message 4 of 5
Any decent mid-range and above ASUS or TP-Link router will be fine.
Just make sure it has gigiabit (10/100/1000) ports on it.
  • 14.33K
  • 594
  • 1.38K
Message 5 of 5
Get that one will by fine.
