Activate v6 box
Hi, I need to activate my v6 box but when I call the activation line it says call centres are all closed. Keeps cutting me off. How can I activate? Thanks
  • 24.82K
  • 1.43K
  • 3.16K
Re: Activate v6 box
The activation line is automated. What number are you calling?
Re: Activate v6 box
0800 953 9500
Is that the right number? Thanks
  • 3.9K
  • 625
  • 851
Community elder
Re: Activate v6 box
Hi Tashajade,
VM have recently started pre-activating their equipment, and the box should call "home" and be activated within 30 minutes, however sometimes this fails and the advice is to sign into Service status at the top of this page and run a test against the TV box you are installing. By doing this we’ll be able to reboot the box or put you in touch with the right team.
The old method was to reboot the V6, and if the channels are still greyed out then you need to phone to get your box activated. 0800 953 9500.
You will need the box serial number, and your account and area number.
You could also try contacting  New accounts and Set Up for them to complete the setup and activation.
That would be options 1,1,1 and 4 if dialling 150 from a Virgin landline , or options 1,1,2 and 4  if dialling 0345 4541111 from any other phone
Dave
