on 14-01-2023 17:08
Accidentally cut a green cable with a thin blue wire inside about around 8cm under our front garden and now my internet is gone. We've got a technician booked for Tuesday but not sure if we should inform them that it's a problem with the outside cable incase they need something else to fix it?
14-01-2023 17:13 - edited 14-01-2023 17:15
@Pingu1357 wrote:Accidentally cut a green cable with a thin blue wire inside about around 8cm under our front garden and now my internet is gone. We've got a technician booked for Tuesday but not sure if we should inform them that it's a problem with the outside cable incase they need something else to fix it?
If the cable is accessible the engineer will attempt to 'patch' the it until a new one can be run by a different team.
on 17-01-2023 08:04
Hi Pingu1357,
Thanks for using the forums to get this issue with your cut cable looked into, I am sorry if this has been causing some anxiety for you.
Just like Carl_Pearce mentioned already, the engineer will pop a temporary measure/repair in place and they should book a prepull appointment for a later date to have the cable repulled and repaired fully.
If you have any issues with this after the engineer visit today please let us know.
Megan_L
