on 23-09-2023 14:22
Hi there, my previous set up worked fine, but the new one with the Hub5 does not, what do I need to change or replace.
Previous set up: Hub 4 and network switch TL link SG1008D 8 port, link below.
Answered! Go to Answer
on 23-09-2023 14:28
I don't see a reason why that switch wouldn't be compatible with the HUB 5, when other wired devices are working.
All I can suggest is trying another switch, like below, to troubleshoot.
https://www.amazon.co.uk/NETGEAR-Ethernet-Unmanaged-Internet-Splitter/dp/B07PWHGQSS
on 23-09-2023 14:28
on 23-09-2023 14:38
Have you tried the switch in all of the ports on the Hub5 ?
23-09-2023 14:59 - edited 23-09-2023 15:11
Just a thought, has the TL link SG1008D 8 port switch & all the attached kit been power off since the Hub 5 arrived ?
I ask because network switches make an internal map of the network, and that map needs to be forgotten / re-created when a key component like the VM Hub is replaced.
on 23-09-2023 15:26
I'll elaborate on Client 62's reply. From https://community.fs.com/blog/unmanaged-switch-basics-and-faqs.html
"The unmanaged switch is the data link layer device. It can identify the MAC address information in the data packet, then forward it according to the MAC address, and record these MAC addresses and corresponding ports in an internal address table of its own. When a device sends a packet to another device, it enters the switch and the switch reads its header to determine what to do with it. It matches the destination address or addresses and sends the packet out through the appropriate ports that leads to the destination devices"
Being P-&-P I doubt that it needs rebooting - but that is the usual golden rule!
on 23-09-2023 15:37
Go get a router with 1Gb ports and use hub in modem mode
on 23-09-2023 16:13
on 01-10-2023 07:14
Hi John. Thank you for the reply.
yes tried that. And strangely didn’t help. 😞
on 01-10-2023 07:15
Hi there.
this was a great suggestion. But still not working. 😕
on 01-10-2023 07:17
Thanks for this, would there be a setting in the router I would need to tweak? Ps. I am using the Wi-Fi of the hub 5 so don’t want to put it in router only mode.
