  • 531
  • 10
  • 42
Fibre optic
9.1.1912.302 FIRMWARE UPGRADE
my hub has just updated to 9.1.1912.302 from 9.1/1811.401
2 files downloaded
12/11/2020 22:54:11noticeSW download Successful - Via Config file
12/11/2020 22:52:13noticeSW Download INIT - Via Config file
speed seems ok-normal
what is the update for, and is this change normal?
I see a few other members have reported this with some issues.
  • 5.88K
  • 1.11K
  • 1.55K
Re: 9.1.1912.302 FIRMWARE UPGRADE
Hello
The update was for a few bugs fixes that have been fixed, I have had mine for close to a month in modem mode and having no problems.
Regards Mike
