  • 12
Message 1 of 13
5ghz wifi drops out
I keep getting 5ghz wifi drops.  Every device that connects drops for 60 seconds and the network disappears.  I have tried setting the 5ghz channel manually to 48 and disabling channel optimisation however after a few minutes the channel defaults back to 44.  Any ideas please?
  • 24.77K
  • 1.43K
  • 3.15K
Message 2 of 13
Re: 5ghz wifi drops out
Factory reset the hub and see how it behaves after that
  • 12
Message 3 of 13
thanks for the suggestion.  ive tried that and its not any better
  • 11.91K
  • 927
  • 1.53K
Message 4 of 13
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
Mike Robinson
  • 12
Message 5 of 13
Yep I already had the 2.4 and 5ghz bands split.
Here are my router stats, I did a reboot about 1 hour ago and ive had another 5ghz wifi drop about 5 minutes ago.  Nothing on the log.
1 203000000 10.4 40 256 qam 9
2 211000000 10.1 38 256 qam 10
3 219000000 10.4 38 256 qam 11
4 227000000 10.4 38 256 qam 12
5 235000000 10 40 256 qam 13
6 243000000 10.4 38 256 qam 14
7 251000000 9.9 38 256 qam 15
8 259000000 10.4 38 256 qam 16
9 267000000 10.1 40 256 qam 17
10 275000000 10 40 256 qam 18
11 283000000 10 40 256 qam 19
12 291000000 10 40 256 qam 20
13 299000000 10.1 40 256 qam 21
14 307000000 9.8 40 256 qam 22
15 315000000 10 40 256 qam 23
16 323000000 9.9 40 256 qam 24
17 331000000 10 40 256 qam 25
18 339000000 9.9 40 256 qam 26
19 347000000 10 40 256 qam 27
20 355000000 9.6 40 256 qam 28
21 363000000 9.6 38 256 qam 29
22 371000000 9.6 38 256 qam 30
23 379000000 9.4 38 256 qam 31
24 387000000 9.5 38 256 qam 32
1 Locked 40.3 1553 597
2 Locked 38.9 6 0
3 Locked 38.6 6 0
4 Locked 38.9 7 0
5 Locked 40.3 2 0
6 Locked 38.9 7 0
7 Locked 38.9 2 0
8 Locked 38.9 5 0
9 Locked 40.3 8 0
10 Locked 40.3 10 0
11 Locked 40.3 7 0
12 Locked 40.3 8 0
13 Locked 40.3 3 0
14 Locked 40.9 6 0
15 Locked 40.3 5 0
16 Locked 40.3 8 0
17 Locked 40.3 6 0
18 Locked 40.3 2 0
19 Locked 40.3 5 0
20 Locked 40.3 3 0
21 Locked 38.9 8 0
22 Locked 38.9 9 0
23 Locked 38.9 8 0
24 Locked 38.9 9 0
1 53700230 40.5 5120 64 qam 2
2 60299990 40.3 5120 64 qam 1
3 46200000 40.5 5120 64 qam 3
4 39400000 40.5 5120 64 qam 4
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
  • 24.77K
  • 1.43K
  • 3.15K
Message 6 of 13
Your downstream levels are too high.
You'll likely need an engineer.
  • 12
Message 7 of 13
Thanks.  Ive added in a 6db attenuator and looks better, however I dont understand why this would affect wifi drops?
1 203000000 4.5 38 256 qam 9
2 211000000 4.1 38 256 qam 10
3 219000000 4.5 38 256 qam 11
4 227000000 4.4 38 256 qam 12
5 235000000 4 40 256 qam 13
6 243000000 4.4 38 256 qam 14
7 251000000 4 38 256 qam 15
8 259000000 4.4 38 256 qam 16
9 267000000 4.3 40 256 qam 17
10 275000000 4.1 40 256 qam 18
11 283000000 4.1 40 256 qam 19
12 291000000 4 40 256 qam 20
13 299000000 4.3 40 256 qam 21
14 307000000 3.9 40 256 qam 22
15 315000000 4.1 40 256 qam 23
16 323000000 4.1 40 256 qam 24
17 331000000 4 40 256 qam 25
18 339000000 4.1 38 256 qam 26
19 347000000 4 40 256 qam 27
20 355000000 4 40 256 qam 28
21 363000000 3.9 38 256 qam 29
22 371000000 4 38 256 qam 30
23 379000000 3.5 38 256 qam 31
24 387000000 3.7 38 256 qam 32
1 Locked 38.9 5 0
2 Locked 38.6 5 0
3 Locked 38.9 4 0
4 Locked 38.6 5 0
5 Locked 40.3 0 0
6 Locked 38.9 6 0
7 Locked 38.9 0 0
8 Locked 38.9 4 0
9 Locked 40.3 4 0
10 Locked 40.3 4 0
11 Locked 40.3 7 0
12 Locked 40.3 5 0
13 Locked 40.3 0 0
14 Locked 40.9 5 0
15 Locked 40.3 5 0
16 Locked 40.3 6 0
17 Locked 40.9 5 0
18 Locked 38.9 5 0
19 Locked 40.3 5 0
20 Locked 40.3 6 0
21 Locked 38.9 4 0
22 Locked 38.9 5 0
23 Locked 38.9 6 0
24 Locked 38.9 6 0
  • 11.91K
  • 927
  • 1.53K
Message 8 of 13
 ... snip ...
If the Hub is struggling to keep a connection it will be noticed downstream and the weakest part of the downstream is the 5GHz Wi-Fi.
Mike Robinson
  • 24.77K
  • 1.43K
  • 3.15K
Message 9 of 13
Better now with the attenuator.
Having the levels too high can cause the connection to drop out.
Did any wired connections drop out?
  • 12
Message 10 of 13
yes as far as i can tell wired connections also drop.  this is happening at exactly 24 mins past the hour ever hour now.   the disconnect lasts approximately 1 minute then reconnects.  not great when you have skype and teams calls
