5ghz not working on my hub 2AC
I noticed over a week ago my hub light for 5ghz was missing. I have been online and followed all the guidance. I have unplugged, reset everything, checked that 5ghz is switched on in the router settings and it is.
I have tried to contact VM and keep going round in circles. I can't see that I can order a replacement etc. and the testing just keeps taking me round in a loop.
Please can someone get back to me. This really frustrating me now!!
  • 6.51K
  • 490
  • 859
Hero
Re: 5ghz not working on my hub 2AC
It may be a good idea to carry out a factory reset on the Hub …
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
