5g and 2g not showing
Hi had to do a factory reset on my hub snd the 5g and 2g networks no longer appear on my WiFi options. Can anyone suggest how I get them to appear once more.
thanks
Tags (1)
  • 11.82K
  • 925
  • 1.52K
Re: 5g and 2g not showing
Log into the Hub Settings and navigate to the Wireless options and have a look in there,
or,
Factory reset the Hub using this exact method ...
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
  • 24.7K
  • 1.42K
  • 3.14K
When you reset the hub it will change to the default SSID and password as printed on the bottom of the hub.
You’ll need to login to the hubs admin pages and change the SSID and password to how you want them to be.
thanks, have gone into hub settings and it shows that 5g snd 2g are present. But can’t see them when I then search for networks on other devices.
will try second option again
jason
