on 13-02-2023 09:48
How do I order a 2nd pod? I was told I could do it through the connect app but it won’t open when the speed is only 0.05mbps. The pod I have keeps losing connection with the hub and can’t be detected so I think it’s too far away and probably needs a 2nd pod to fill the gap, I’m getting really fed up having to keep rebooting the pod 2 or 3 times a night, someone please help me. Thanks in advance
Answered! Go to Answer
on 13-02-2023 16:09
on 13-02-2023 16:09
on 14-02-2023 10:13
Thank you for replying, I moved the pod to the same room as the hub and still not detected on the connect app, I don’t know if it’s developed a fault, there’s no light on it and it’s warm to the touch but that could be normal, as you can probably tell I’m not tech minded, I’ll give virgin a ring and hopefully won’t have a battle to get a new pod
on 14-02-2023 10:28
on 16-02-2023 14:00
Thanks for your post on our Community Forums @Mrs_T2, and a very warm welcome to you! 😊
Sorry to hear of the issues experienced on the Wi-Fi connection.
Can you possibly place the Wi-Fi pod in either 1 or 2 rooms away from the router?
It sounds like the first location might have been a bit too far away and then new location (being in the same room) is a little too closer to benefit an extension of the Wi-Fi signal.
If you're able to possibly advise us of a description of the layout of your property, as well as where the router is located and which areas struggle for Wi-Fi signal, we maybe be able to advise where best to place the Wi-Fi pod.
Kindest regards,
David_Bn
