  • 9
Message 1 of 16
2 x virgin mobiles not connecting to internet via hub 3.0
Recently joined Virgin Media and both kids have virgin mobiles. They can no longer connect to hub 3.0 for internet access. I had a look at the hub last night and it looks like quite a few errors in the log. I keep having to restart the hub every few days to keep everything connected which I don't think is acceptable and should not be necessary. Can anyone shed any light why devices can connect to the hub but have no internet access? TIA
  • 11.46K
  • 889
  • 1.46K
Message 2 of 16
Re: 2 x virgin mobiles not connecting to internet via hub 3.0
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 11.46K
  • 889
  • 1.46K
Message 3 of 16
Can you please
Mike Robinson
  • 24.39K
  • 1.4K
  • 3.1K
Message 4 of 16
Is it just those 2 devices affected?
  • 9
Message 5 of 16
  • 9
Message 6 of 16
13310000001.440256 qam25
22030000003.440256 qam9
32110000003.240256 qam10
42190000003.240256 qam11
5227000000340256 qam12
62350000002.940256 qam13
72430000002.540256 qam14
8251000000240256 qam15
92590000001.740256 qam16
102670000001.240256 qam17
112750000000.940256 qam18
122830000000.740256 qam19
132910000000.740256 qam20
142990000000.940256 qam21
15307000000140256 qam22
163150000001.240256 qam23
173230000001.440256 qam24
183710000001.440256 qam26
193790000001.540256 qam27
203870000001.540256 qam28
213950000001.540256 qam29
224030000001.240256 qam30
234110000001.440256 qam31
244190000001.240256 qam32
1Locked40.3110
2Locked40.3260
3Locked40.3280
4Locked40.9280
5Locked40.9290
6Locked40.9250
7Locked40.9240
8Locked40.9180
9Locked40.3180
10Locked40.3300
11Locked40.9220
12Locked40.3250
13Locked40.9260
14Locked40.3360
15Locked40.3420
16Locked40.9290
17Locked40.9270
18Locked40.3120
19Locked40.9220
20Locked40.3130
21Locked40.3200
22Locked40.3180
23Locked40.9160
24Locked40.321
0
13939998828512064 qam2
22580000029.5512064 qam4
33260000028512064 qam3
44619999128512064 qam1
2ATDMA0010
3ATDMA0010
4ATDMA0000
  • 9
Message 7 of 16
Not sure what happened at the bottom and hopefully it's usable. It would not allow me to Paste until the site had stripped out invalid html
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
xv9873254k;fg87dsfd;kfoA,.iye
SFID474
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID473
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
15/11/2020 12:04:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 23:12:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 18:39:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 00:29:22noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 00:29:22ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 20:00:10noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 03:22:54criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 01:10:53noticeSW download Successful - Via NMS
09/11/2020 01:09:3noticeSW Download INIT - Via NMS
07/11/2020 23:45:34noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/11/2020 23:45:34ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 20:44:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 12:14:2noticeSW download Successful - Via Config file
04/11/2020 12:11:32noticeSW Download INIT - Via Config file
03/11/2020 01:03:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 01:03:9Warning!B-INIT-RNG Failure - Retries exceeded;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 01:01:53criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 00:57:52noticeNOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 00:47:32criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/11/2020 00:46:57Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 11.46K
  • 889
  • 1.46K
Message 8 of 16
Your Upstream Power Levels are too low.
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 9
Message 9 of 16
Fantastic response. Thanks.
Was not looking forward to calling VM as I'm not a techie and would probably struggle to explain over the phone. I'll hang on a few days and see what happens. I'm lucky enough to be going to work atm so I'm not around much at home this week. Thanks again
  • 11.46K
  • 889
  • 1.46K
Message 10 of 16
While you are waiting you may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
Mike Robinson
