2 broadband cable connections on wall
I have 2 different sized Internet connectors in my wall. One I use for virgin. Does that mean the other one could be used for other providers? I want to switch providers but was under the impression it would mean I need to get an engineer out to switch connections because I'm on broadband. Something I'm keen to avoid during covid.
Does this 2nd connector mean I might already be set up and I can just plug in a new router myself from the new provider?
Tags (1)
  • 4.66K
  • 856
  • 1.24K
Re: 2 broadband cable connections on wall
Hello
Can you please post a photograph of the sockets, VM uses their own infrastructure and it is different to that of the other providers, what does the box have written on it.
Regards Mike
  • 20.96K
  • 1.13K
  • 2.7K
Depends what the second connection is for.
And usually you can’t just “plug in a router” as it will also require some form of modem (VDSL or Cable) or a 2-in-1 hub.
