2.5G Port on Hub 5 in Modem Mode
dzw003
Hi all,
I’ve been on the Gig1 plan for a while now. Have been on the Hub 4 and ended up buying a dedicated router (TP Link Archer GX90 (w, 2.5 Eth port) due to the atrocious Wi-Fi on the Hub 4.
I recently managed to convince Virgin to give me the Hub5 when I called in to renew.
So my question is, with the Hub 5 in modem mode and connected to my router using the hubs 2.5G port number 4, will I be able to achieve 2.5G performance to my PC, when connected to my TP Link routers 2.5 port? Sorry for the long winded question!
Or can I only use my Hub in router mode to achieve 2.5G capable speeds?
Just to clarify, my PC has a 2.5G Ethernet Port and all ethernet cables used are minimum Cat6a.
Would be cool to benefit from the full speeds of the Gig1 package instead of ≈940mbps.
Cheers!
10 REPLIES 10
@dzw003 wrote:
Just out of curiosity, would this router work? It seems to have dual 2.5G ports but at quite a reasonable price in comparison to others offering the same. Made me slightly suspicious!
https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/tuf-gaming-ax6000/
I've been using this router for a while, but in AiMesh mode.
Full bandwidth from Gig1 (Get full speed with a PC (2.5Gbps Ethernet) > AX6000 (2.5Gbps Ethernet) > NETGEAR MS108EUP (2.5Gbps switch) > RT-AX86U (Aggregated to two Gigabit ports on 2.5Gbps switch) > 2.5Gbps WAN port on RT-AX86U > 2.5Gbps port on HUB 5).
